What you'll need...
A donor electric guitar
A box
If adding a second pickup...
(I've always been a fan of musicians that run 2 amps to their guitar ala Bob Log III)
A piezo buzzer
1 potentiometer
A 1/4 inch female mono jack
1 volume knob
all the above can be had at your local Radio Shack
And other things you'll need...
Screwdrivers
Soldering iron and solder
some extra wire length (I used an old headphone wire)
Wood glue
A Dremel
A drill with various drill bits
and a means for cutting wood
Everything else will be supplied by the donor guitar.
Remove these ads by
Signing UpStep 1Break 'em On Down...
Start by removing the strings.
After that the neck will unscrew from the body.
Then you can unscrew the bridge and pickup.
You will have to cut the wires from the pickup and give yourself room on the pickup wiring. You will be soldering them back together.
Unscrew the pick guard and the cover on the back.
The volume and tone knobs can be pried up and off.
You then can unscrew the bolts holding the potentiometers and the mono jack.
And don't forget the jack plate and screws.
Keep all the wiring intact with the exception of the wires you cut to get the pickup out. Set aside everything you take off the donor guitar as you will need them.
At this point you should have something like the picture. Now would be a good time to remove the hinges from your jewelery box as well.
It's very familiar to me, but I can't seem to place it. No luck searching online so far, either, but I won't stop 'til I figure it out. :)
Thanks again
http://www.youtube.com/watch?v=x2-EL6Pk2L0
Enjoy!
"cigar box guitar" it's more recogniceable and will allow more users to come by your ible :)
This is the term the community of cigar box guitar builders uses so I think that would be more convienient to use :)
Just a suggestion.
nice ible btw
You're right although it's in the style of a cigar box guitar, since it doesn't really use one you can't really call it that indeed.
I didn't say anything :)
