Step 10Disinfecting and Filling the Reservoir
First of all, the reservoir and growth medium has to be disinfected prior to use. All you need is a bathtub, some hot water and some chlorine bleach. The clay pellets a covered in dust before their first use so I rinsed them off before filling each mesh basket with them (Figure 10B). I laid all six mesh baskets in the empty reservoir and then added a generous portion of chlorine bleach. I filled the reservoir with hot water and let the whole thing sit for about an hour. Then I gave everything a quick rinse and it was ready to be filled.
The water level here is important. At first the roots probably won't be sticking out of the rockwool cubes so you should fill the reservoir up to soak the cubes directly. As the roots grow down it is necessary to lower the water level until there is a small gap between the surface of the water and the bottom of the mesh pot. The roots should have to pass through a small air space between the pot and the solution.
Now to prepare a good nutrient solution, a few skills in mathematics are required. Most hydroponics nutrients come in a very concentrated form that must be diluted before the plant can use it. The bottle should give you an amount of nutrient to mix with an amount of water (Figure 10C). As you can see the nutrient comes in three parts that must be mixed in different proportions depending on the stage of the plant's growth. The bottle only lists how much of each nutrient to mix with 100 liters of water. Since my reservoir does not hold that much I need to come up with an equation that generalizes how much I need to add to any volume of water.
Vn = (Vr/100L) x Vb
Where:
Vn = Volume of nutrient needed (ml)
Vr = Volume of water in reservoir (L)
Vb = Volume of nutrient per 100L as listed on bottle (ml/100L)
For example, when I first filled my reservoir I used 14 liters of water to accomidate my plants through the vegetative growth stage. The amount of nutrient listed on the bottles were:
FloraGro: Vb = 396 ml/100L
FloraMicro: Vb = 264 ml/100L
FloraBloom: Vb = 132ml/100L
Therefore the volumes of nutrient I had to add to my reservoir were:
FloraGro = (14L/100L) x 396ml/100L = 55 ml
FloraMicro = (14L/100L) x 264ml/100L = 37 ml
FloraBloom = (14L/100L) x 132ml/100L = 18 ml
Of course, all of these volumes have to be measured accurately. For the water I used a measuring cup and for the nutrient I used a syringe. A pen, some paper and a calculator also comes in very handy when doing this task (Figure 10D).
5
comments
Add Comment
Add Comment
