My Mini Stove (Instructions By NK5)
  • last photo ←
This is a Mini stove that i built using NK5s' instructable Mostly i did a slide show to show NK5 and a few others some pictures (i didnt want to crowd his comments with my pics)
I did make a few little changes, i used cotton balls and rubbing alcohol (instead of HEET and fiberglass) I used a candle to preheat for about 1 minute. At first it made a huge flame after about 5min or so it died down. While putting on the lid the top tore, adding another hole for flame to come out.
this is not an instructable nor is it intended to be thats why its a slide show
UP DATE (new pics posted may not be up for and couple hours)
I made a new lid, and further moded the inside. The new lid has fewer holes, using 3 different sizes. The inside has a thin layer of cotton at the bottom covered in a thin layer of steel wool (#0000) and then a cotton ring on top the idea is the bottom cotton layer will never need changed and the top ring will last for at least 3 full burns.
new use: ROAST MARSHMALLOWS!!!!
28 comments
Mar 20, 2011. 4:03 PMA flyin muffin says:
The holes in the sides are too big. You also only need one hole in the top to pour alcohol in. The side cracked because you didn't stretch out the top and/or crimp the sides of the inside can. (click here to see crimping)
Hope this helped :)
Jul 19, 2010. 10:17 PMceladood says:
Is it okay to mix different fuels? not purposefully, but lets say i used HEET one day, but I ran out, and decided to use rubbing alcohol instead. Would this be okay?
Apr 14, 2008. 4:47 PMCrakamiester93 says:
Is it safe to eat roasted marshmallows on a stove that uses HEET? It says that the vapors are poisonous...
Nov 13, 2009. 3:01 PMjunits15 says:
they are poisonous to breathe in, but once they are burnt they are fine
Oct 22, 2009. 2:26 PMjunits15 says:
The only thing is steel wool will rust (rather quickly from the increased surface area) and possibly contaminate your stove. (food too?)
Oct 1, 2009. 4:11 AMjames.mcglashan says:
the hole in the middle is fixed by a screw or a pot killing that evil flame hole cheers and have fun with the MARSHMALLOWS
Jul 14, 2009. 1:12 PMownedintheface says:
can you use rubbing alcohol instead?
Jun 29, 2009. 10:50 PMstriker31337 says:
http://www.csun.edu/~mjurey/stove.html has complete instructions on how to make and use a penny stove.
Feb 16, 2009. 1:37 PMjunits15 says:
every time i see the word crack i think of this................................HEY I NEED A NEW BUTT MINE HAS A CRACK IN IT!!!!!!!!!!!!!!!!XD XD XD XD
May 29, 2008. 2:26 PMwhitedem0n says:
... what is HEET?
Dec 13, 2008. 9:33 PMMicrotek says:
HEET is a Gas Line Antifreeze and Water Remover made to put in your car during winter months to avoid freeze up.
Dec 13, 2008. 8:01 PMMicrotek says:
We sell these at www.Microtek.MyBisi.com for $10.00 for those of you that want one...
Dec 13, 2008. 9:30 PMMicrotek says:
A few of our friends weren't too handy so we started selling em. We tried the insulation but found it to be a waste of money(and itchyness). Ours is hollow. When full, they'll burn 15-20 minutes, and hot enough to boil water (on denatured alcohol). The best way to get them started is the "spilling-fuel-all-around-it" method.(lots of videos on youtube on 'lighting your penny stove'). Once the fuel starts to boil(you can hear it), cover the center hole with a coin and you burn only the fuel vapors.
Aug 10, 2008. 6:15 PMThelonelysandwitch says:
Try putting some oil in the middle of the steel wool and the cotton ring it will burn longer and hotter (or if you put too much oil and don't let in enough air it will explode).
Jul 26, 2008. 9:07 PMcowtipper97 says:
I just tested my new stove based on your design. When I was building i found a way to fit the two cans together with out making the inner can's wall bend at all. But unfortunately it is impossible to separate the two cans to replace the top ring of cotton. I had to drill out the fill holes to make one large fill hole 1/4 inch to remove all the cotton and steel wool from inside. Other than that it worked great and had a good size flame. Nice Pictures. I can't wait for the next time i go camping!
May 29, 2008. 2:29 PMwhitedem0n says:
I have to agree it's dangerous to roast marshmallows (and eat them) over an aluminum can stove
Feb 29, 2008. 3:38 PMthe gizmoman says:
gets some j-b weld it works great for building stoves
Feb 3, 2008. 10:32 AMwasserman08 says:
ya i did this a while back from one of the other instructables my friend made a couple different kids.
Feb 1, 2008. 6:58 PMSurferGeek says:
Feb 1, 2008. 10:01 AMlebowski says:
nice photos.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:i make shooting things
