My Mini Sumobot (500g Prototype)
 by ASCAS
Featured
Here's my mini sumobot, running for the national sumobot competition (Philippines). After the competition (January 12 & 26) I'l probably release a full step by step tutorial, provided with some old codes. This guide will help you understand and provide you ideas on how a typical sumobot works.
What's A Sumobot?
It's somehow related to real life sumo wrestling. Two sumobots are placed in a ring, the goal is two push each other out of the ring, any part of the robot that touches outside the wring will be considered defeated. The one who pushed the other opponent out of the ring will be the winner of the round, there will be three rounds in each battle. It's a championship that will test your skills in programming and in building your hardware.  There are three divisions in our country the 400g, 500g and the 1kg. It's Fully Autonomous (has no remote controls, run 100% with programs)
I'm actually using an "Arduino UNO" clone, the ACEduino, as my micro controller. The current motors installed are two mabuchi (Torque-Dash Motor) installed in a "Tamiya Twin Gearbox" (203:1). Motors are driven the by my DIY Motor Shield (<- Instructable Guide) using a L298N motor driver chip.
The bot contains 9 sensors in total. There are 3 floor sensors, 2 side sensors, 3 front sensors and 1 rear sensor. It's powered by a 7.5v 950mAh rechargeable LiPo battery and has a battery life of 1 hour (continuous battle). The body is all acrylic, I cut it using a rotary tool. It weighs 450g and has a pushing force of 1.9kg. It's not that fast but it surely has a lot of pushing power "torquey".
National Robotics Competition (Elimination):
This time the sensors are fully functional: Floor, Front, Side, Rear.......
Here's a video of my two prototype sumobots fighting in battle:
The only working sensors in the demonstration are: 2 Floor Sensors, 1 Rear, 1 Front.
We are still on the programming stage, the bot only operates with some primitive functions,
soon we will input strategical tactics.
_______________________________________________________________________________________
WATCH THIS! My version 6, FAC3PALM in testing action
Here's My Version 6 named "FAC3PALM" (500g Mini mrk6). About 5-10x faster compared to the previous one.
FAC3PALM is running with two modified gearheads, equipped with re-winded Tamiya "PLASMA" motors. The motors are powered by a "Pololu Dual VNH5019" (12A-30A arduino motor shield) and connected to a selectable 2-3 cell Li-Po battery. This somehow results to a 650-790 rpm range of speed.
A Highly Competitive Mini Sumobot: (Akir4)
(not mine)
A Typical Sumobot Championship Battle:
(not mine)
ASCAS (author) says: Jan 3, 2013. 4:46 PM
Thanks! In our country 500g sumobots should have a maximum of 15cm-by-15cm. And yes they thad to fit in a square.
My bot has a measurement of 15cm-Depth, 14.5-width, 7cm-height.
Oh and yes! You can make your bot as tall as you want, as long as it fits in the box.
lewisb42 says: Jan 3, 2013. 9:35 AM
Sweet-looking 'bot. How big is it? I ask because the 500g competition I was in specified bots had to fit in a 10cm-by-10cm square (but could be as tall as needed within that square).
Kiteman says: Jan 3, 2013. 1:57 AM
*Looking forward to full write-up*
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
