Luego de haber hecho dos versiones de sopletes de un solo carbón, esta y esta, finalmente decidí que ya era hora de experimentar lo que hizo Phil B hace un tiempo. Obviamente, lo hice a mi manera, con las cosas que encontré a mano.
After making two versions of single carbon torches, this and this, I finally decided it was time to experience what Phil B made some time ago. Obviously, I did it my way, with the things that came to hand.
Remove these ads by
Signing UpStep 1Handles (mangos)
I started by making sure that with my old things have enough materials for the project. First, I took an old pine wood stick, square section, 1 inch of side. I cut two pieces of about six inches, using the ends having recesses for joint. These recesses serve to allow the opening of the arms of the device. The wooden pieces are the handles.
KEEP UP THE GOOD WORKS..........
will try to build a bigger electrical transfo, based on a bigger nucleus and/or different caliber, number or primary-secondary ratio of the copper wire used. also could try with my welding machine directly, as power is already availbale there.
a detaiil... coppered carbon electrodes were used in "old fashioned" movie halls projectors or lighting equipment for movies/aso too
and as I read: "A single carbon rod can be used to tack stainless steel sheetmetal," , i use for small work carbon (pos.) rods from D,C or AA discharged zinc /acid batteries f.i.. More power is needed, because welding doesn work now.
I realize bronce rods from alkaline (neg) batteries also could be useful for small work, if less power is enough.
Interesting. A single carbon rod can be used to tack stainless steel sheetmetal, prior to TIG welding.
I am curious about the Schiavoni Ecological motor, could you please indicate where I might find information on it ?
Regards,
Dennis
diaden@ihug.co.nz
Obvious, in the journey one makes flaws, fails, errors, setbacks, some of them dangerous. But that is the only manner.
I am curious, semi retired, have TIG, and stick welders, lathe & mill attach, oxy acetelene, etc.
Cheers,
Dennis
I am retired since 01/01/10, I have a cheap stick welder and some electric hand tools, only. I like to design and to build little things, I am NOT perfectionist, I am content the things work. Besides of the mentioned motor, I have thinked a pulsorreactor motor that is different than existing, very simple. Maybe during 2011 I have time to attack it.
Just a life experience, I think the time that the arc is struck is longer than normal welding and the longer arc length puts out more UV so cover up well!
Not my vid, but this guy shows localized heating of metal with his carbon arc.
Nevertheless, I will try to do a "before and after", maybe that will be sufficient.
About the opinions, I learned to don't hear others, because i.e. a film can be the best of the universe for you, and the worst for me.
The stick welding requires a lot of manual skill too; if you look my weldings, they are ugly, ugly, ugly, but enough good for my needs.
Pay attention also to the "one carbon arc torch", it is very useful sometimes.
Thanks for your concern!
I need to make one of these!
It is easy to make! And very cheap, almost free.
I see you are using the copper-coated carbon arc rods which you said were hard to find in your country.
Yes, I found these rods in "La Casa del Soldador" (Welder's House) in La Plata, about 20 km from my home.
