My Pump Action Shotgun V2.5
PlayK'NEX by
1,334
Posted
Introduction: My Pump Action Shotgun V2.5
It is a fairly powerful gun with a true trigger and working pump with a 15 shot mag.
I built this in layers so it should be easy to follow the instructions
if you have some knowledge of knex.
1. This gun.
2. Original gun
3. New pump
I recommend that you keep a Grey with you when you are using this gun. To clear Jams just pul back the firing pin and push the Grey down the barrel to push the red back in place, then pull the Grey out.
You can make the mag a large as you want just extend the top.
You might want to make the next version depending on what you use it for. instructables.com/id/My-Pump-Action-Shotgun-V37/
Step 1: Making the Handle
Same handle i use all the time. fairly simple
Step 2: Making the Body
1. Build all these.
2-3. Build this also.I just couldn't be bothered to take it apart.
Nothing much else to say. just look at the pictures.
The last pic is of the pump mech.
Step 3: Making the Trigger
I think that you can just use a green instead of the yellow but im not sure.
Step 4: Puting It All Together
Just follow the pictures and ask if you have a problem.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    131 Comments
    success! a pump action that shoots rods and not orange connectors!
    rated 5*   made a way better pump annnnd extensively modded mine to look like a SPAS12
    LOL doesn't even look like my gun. :-)
    haha i know but thats mainly because i didnt have enough pieces ahahaha
    I have been thinking about remaking this gun. if you poet closer pics of the pump i will add it to the gun and give you credit.
    here it is, i basically just added the brown/orange conectors and the two green connectors underneath to keep the pump pull back smoothly. i also made a new trigger because the old one would interfer with internals if it wasn't modded
    Thanks when i get around to remaking this gun i will add this to it. :-)
    I remade the gun with the new pump and it fires shotgun style now. i will post within a few days hopefully.
    awesome man can't wait to see it
    PLEASSSSE POSSSSST
