Introduction: My SEP /// SEGV-3 (Shell Ejecting Pistol /// Shell Ejecting Gun Version 3)
This is my 5th 'ible (yay).
This is my SEP or SEGV-3. to whoever has seen my SEGV-2, this is a following version of my SEG series. the SEGV-1 was the first version of the series, and it was very bad, so i didn't even bother posting it, and took it down a day after i ad finished building it. the SEGV-2 was also not that good, but it was at least a true trigger with a handle and a decent mech, so i decided to post it. this gun, the last and best in the SEG series, was made in 2 days, after i took a big break from building shell ejectors. this pistol is truly amazing and i will show the pros and cons below:
PROS:
comfortable
easy to use
easy to load
powerful
symmetrical (unlike the previous versions of the series)
long range (60-65ft with 6 doubled up bands (12 bands in total))
very sturdy and strong
good shape
never breaks
small, doesn't use a lot of pieces
portable
all broken pieces can be subbed for non-broken pieces, and the non-brokens aren't all that bad
big magazine, can hold 10 round/bullets, can be built bigger
flawless (so far and for me, at least)
comfy handle
(of course) true trigger
strong structure
relatively accurate
and (of course), last bot not least - ejects shells
CONS:
has broken pieces, though all of them can be subbed for non-broken pieces, as i said before
you need to be careful after shooting all your shots not to shoot at the mag pusher because that's trouble
relatively big and long for a pistol
mag can bend a little at the sides because of no support (can be fixed by adding 2 more support layers on the outside of the mag, i did it a day after i finished uploading pictures lolz)
Demonstration of shooting my SEP / SEGV-3:
How to load my SEP / SEGV-3:
PROS:
comfortable
easy to use
easy to load
powerful
good shape
never breaks
portable
comfy handle
strong structure
relatively accurate
CONS:
Step 1: Trigger, Ram, and Mag Pusher
pics:
1. the trigger
2. the block
3. connect like so
4. put a rod through the 3-way connector of the trigger
5. ram
6. close up of the ram
7. tape and bands
8. "ram bands"
9. mag pusher
Step 2: Handle
pics:
1-3 and 5. different views of the handle
4. the middle layer of the handle
6. get these (optional)
7. attach like so (optional)
8. another view
Step 3: Top Rail
pics:
1. bottom view
2. left side view
3-6. close-ups, read image notes
7. top view
Step 4: Main Body Walls
pics:
1. the two outter walls (identical)
2. the rods sticking out of one of the outter walls
3. the inner walls
