3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Aluminium Foundry
Step 10My First Aluminum Sand Casting
  • last photo ←
After making a good foundry (still working with charcoals) and after making a strong crucible that is not failing after a couple of uses it is time for my first aluminum sand casting.
I started experimenting with sea sand casting which wasn't very successfull so I decided I wanted a good quality mold so I purchsed a 25KG bag of PETROBOND and I have to say it is super for aluminum casting.  It was a bit expensive but I will reuse it many times.
I made a simple Flask for the sand mold made from timber.
I was delighted with my first ever aluminum Star Trek Federation Insignia that I duplicated from a custom plastic resin kit I bought a few years ago.
For more info and links to Metal / Sand casting I made a new blog and everyone is welcome to have a look:
 http://flamingfurnace.blogspot.com/
14 comments
Sep 11, 2011. 6:18 PMbherrboldt says:
All I have to say it thank you so much. I just built my refractory/foundry almost exactly like yours. All I have left is to get ahold of some refractory cement and Im in business. This is awsome. You rock!
Oct 24, 2010. 1:34 PMimbignate says:
Firstly, what sort of sensor are you using for a temperature gauge, and where is it mounted?
Second, what are you using as a mold for the ingots? They're all a nice standard size and very professional.
Third, this is awesome.
Oct 24, 2010. 7:13 PMDIY-Guy says:
Nice technique with filling the gas cylinder with water! An elegant solution to the problem of flammables.
A professional iron worker once told me that cast iron cookware works well for a crucible. There are a variety of pans, pots, "dutch ovens" and other styles to choose from. Maybe there are cast iron muffin pans waiting to be found at a junk sale.
DIY-Guy
Oct 25, 2010. 10:56 PMpaqrat says:
I have been warned about using cast iron cookware if it has not been cleaned of all rust. If I understood correctly, what I was told is the combination of rust and molten aluminum can form something akin to thermite (possibly thermite itself?). If this is the case it could be very dangerous.
Dec 10, 2010. 1:51 PMabsolutekold says:
Ferrous oxide (rust) and aluminium do make thermite. Although the exact ratio's are industry secrets for each company they boil down a lot of rust powder and a lot of aluminium powder mainly for surface area considerations (occasionally it is doped with magnesium to help things along). At any level of rust build up on a pot that doesn't affect it structurally I don't think you have much to worry about. I've never had a problem. but if your worried put the offending rusty item in the smelter with it going full bore for a few minutes (be careful cause this smelter can easily melt cast iron if you are using charcoal ... I speak from experience of loosing an entire melt to this whoops(!?!)) by the time the pot has a barely visible glow in normal light there will be no more rust on it.
Oct 25, 2010. 1:05 PMTANZMEISTER says:
Check out the book by David Gingry. Then you can make your own cast iron cricible
Aug 31, 2011. 1:42 PMbears0 says:
just so you know it's Gingery, not Gingry. :-)
Sep 8, 2011. 6:16 PMTANZMEISTER says:
Details, details. And I suppose you want a crucible instead of a cricible?
Oct 27, 2010. 8:29 PMneffk says:
Nice work.
It looks like you like welding and working with metal. Couldn't you make the sides of the foundry out of masonry or use a temporary form to cast the refractory cement? What you made is really nice, but it sets the bar pretty high for your fellow DIY folk.
Oct 27, 2010. 10:23 PMOrtzinator says:
This makes me wish I had a concrete patio instead of wood.
Oct 25, 2010. 12:57 PMjuanitosy says:
Your step-by-step process showed use of charcoal as fuel, but the video showed use of gas fuel. Can you please explain how you attached the gas line and materials used. Thanks. SYGURONEVADA
Oct 25, 2010. 11:01 PMjuanitosy says:
Thanks for the prompt clarification. I'll use charcoal then when I make my first similar foundry to produce aluminum cast parts to replace broken hard synthetic parts of hardware products like folding dollies and decors. You see I won a warehouseful in public auctions. I hope I can restore the defective products with more durable aluminum parts.
Oct 25, 2010. 1:06 PMTANZMEISTER says:
Great ~ible! Ty!!!
Oct 24, 2010. 7:12 AMhairybaroque says:
Beautifully clear photos and text! So sensible to keep it totally self contained with the charcoal; no feed joints to get a bit too hot and give up. Have you any plans to attempt producing dies to do repeat castings without sand? I like this ible!
Oct 24, 2010. 8:06 AMbasefilm says:
Great work. Clear, practical, useful. I appreciate the descriptions of what did not work (the first crucible) just as much as what did. It is maybe even more valuable from a safety standpoint to be aware of these things. Thank you!
Oct 22, 2010. 9:23 AMThat Inventor Dude says:
Dat is Awesoooome
Oct 20, 2010. 6:47 PMWhales says:
Nice. I dont have plans to make this, but i read your original foundry 'ible and was interested on changes you made.
Oct 20, 2010. 8:29 PMrobbtoberfest says:
Very awesome!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
133
Author:NutandBolt(FLAMING FURNACE)
I have too many hobbies and never enough time. My blogs: Paracord projects: www.paracord-projects.blogspot.com- Metal Casting: www.flamingfurnace.com
