loading
Step 19: Launch and Retrieval
Here's the procedure we used for launch. Try your best to follow what it says. Everything should make sense if you have all the materials. Ignore the "!" after every sentence, i'm not sure why those are there...
While in car, turn on MicroTrak and PocketFinder and start recording coordinates.
1. Arrive at location. Fold out table and chairs.!
2. Place plastic tarp on ground next to table. Place weights on end end of the tarp to
prevent movement by the wind.!
3. Take helium tank out of car and place tank sideways on ground next to tarp.!
4. Place payload box on tarp with parachute.!
9. Unscrew helium tank cap.!
10.Attach hose or similar apparatus to the helium tank regulator.!
11. Stretch hose so it lays halfway on the tarp.!
12.Attach rope to hose about 10 inches from open end of hose. !
13.This rope is then connected to a pull scale that is anchored to the ground.!
14.Hand out latex gloves for those who are holding the weather balloon during inflation.
Two people will be underneath the balloon. Two or three people will be holding the
side of the balloon to make sure that the wind does not move it. Make sure no one is
wearing shark objects such as watches, eye glasses, or highly gelled hair.!
15.Take balloon out of package being sure to not stretch the balloon.!
16.Lay it out on the tarp and locate the open end. Place hose or similar apparatus 10
inches inside the open end of the balloon. Place two zip ties and one tied off rope
around the neck of the balloon that is on the hose to prevent air from leaking out.!
17. Start helium flow to the balloon. Make sure to encourage air flow inside balloon.!
18.Once the balloon has been inflated, read the scale to determine if there is 6lbs of lift.!
19. Once there is 6lbs of lift, tie off the balloon.!
20. With the balloon still connected to the hose, take two pieces of 3ft string. Take the
first piece and wrap it around the back side of the neck. Draw the length until they
are equal. Make an x and loop the higher string through the other string. Position the
string so it is about 7 inches from the end of the balloon. Bring each side of the string
back around them balloon. Repeat this x pattern until the string covered 13mm of e
neck. Make a final knot. !
21.Remove the balloon from the nozzle and hook it to the anchor.!
22.Take you other piece of trying and wrap it around the balloon just as before. Bend
the neck of the balloon so it overlaps the previous tie. Repeat the same process of
tying the balloon as before. !
23.Tie the top of the parachute to the bottom of the balloon, with the ends of the rope
hanging off. !
24.Attach the rope to the top of the parachute.!
5. Open lid and place gps, camera running CHDK, hand warmers inside box. Make
sure all devices are turned on, but camera is not running. !
6. Close and tape lid shut.!
7. Tie two box sling knots around the box.!
8. Attach two of the box sling strings to the parachute hook, and the other two strings to
the rope of the parachute.!
25.Apparatus should be complete.!
26. Press the shutter button on the camera and confirm that the camera is taking
pictures every 30 seconds. !
27. Confirm that he GPS devices are transmitting.!
28. Remove the balloon from the anchor and make sure the payload does not leave the
ground.!
Let it go!
Totally awesome as well as an awesome presentation, what a great job you guiys did, I am proud of all of you that took part in this project. I am a ham radio operator an its so cool to see young people taking part in this type of venture, I will vote for your submission, great job.
<p>Wow! That's really cool experiment!!</p>
<p>its awesome</p>
The work that went into your project and into publishing this guide are impressive. Well done! <br> <br>Do you plan additional flights now that you have all of the prerequsites covered and most of the equipment? Will you be sending additional experiments into near-space?
Well, they would still need to replace the baloon and helium, since the balloon pops during launch, and together the balloon and helium would get kinda expensive to replace over time.
When I said &quot;the balloon pops during launch&quot; I meant that it pops during flight, when it reaches maximum altitude.
Slightly off topic but it would have been amusing if that box was crafted to look like a Love Cube, just encase anyone saw it from up there lol.
That would've been pretty cool :)
<p>WoW... This must be the most awesome project and post ever. You are a real inspiration to many learners, young and old, out in the world. Thank you for sharing so freely. Never give up and keep on pushing the envelope. I will definitely be looking in from time to time. May all your projects in the future be successful. </p>
can we use ardruino instead of rasberry pi they are costly
<p>Thank you so much for this guide! I am running a middle school Science Corps program, and we are planning to launch our first balloon in a few weeks. This guide has been so helpful! </p>
<p>cool one.</p>
<p>amazing! just a few suggestions, one maybe add another camera, two use a wide angle lens, and three, put of of the cameras on the bottom, looking down.</p>
<p>Compressed gas tanks should stay upright.</p>
Hello, I am planning to do a weather balloon launch in a few weeks. I just want to ensure that the balloon has enough lift. How much helium I would need to purchase for about 5.75-6 lbs of lift? My estimate was just a standard 110 cubic feet helium tank.The weather balloon is 1200 grams by the way.
cool one
cool one
um...... your making Space more democratic by making it more American ????
Very nice instructable. <br> <br>I wasn't aware that getting a HAM license is so easy today in the U.S. <br>I made mine 30 years ago, in Switzerland ;-) <br>
It's gotten easier since then.
I really like your project, but isn't it a bit risky for a normal person trying this?
I dont like the way you have to do all this regulatory government stuff just to send a balloon to space. But never the less, nice 'ible.
Got some questions. <br> <br>did the Celluar track all the way to 65k ? at what altitude did you lose the signal from that? what altitude did you reacquire if you lost it ?
Yea, thanks. The cellular pocketfinder only worked up to about 5,000 feet. However, the HAM radio tracked it through the entire flight up to 65,000 and gave us speed and position reports which was pretty awesome. We only got a signal from the PocketFinder when it was almost near the ground. About the last 10 minutes of flight.
ahhh pity. $149 sounded great !! <br> <br>I was thinking of going with a SPOT device. $99 a year and you can get them online for under $100. but at $200 I might as well go the extra $100 and get the micro trak. <br> <br>I plan to push for over 130k (theoretical max is 180k for helium) I might go with hydrogen and push for 150k. its cheaper and you need less of it and it can push higher faster. (it really is not dangerous your 5gallon gas tank is more dangerous) as long as you respect it. <br> <br>Hydrogen (pure) just does not burn or explode as much as people think it does. now mix it with air and WATCH OUT :-) <br> <br>eventually I want to send up a &quot;GLIDER&quot; to drop. <br> <br>and after that I want to push for 200k with a rockoon under the balloon (launch a rocket when the balloon is ready to pop)
We looked at the SPOT, but their prices were way too high in comparison to the microtrak which would provide a much more accurate signal. The SPOT costs $99 for the unit with a $100 service charge and another $50 service charge if you want tracking. Add it up and you get $250 for a device that doesn't even work too well... <br> <br>Good luck.
Hmmm I was informed the every 2 minutes &quot;notifications&quot; of where your at it INCLUDED in the $99 a year no extra charge. $50 if you want LIVE tracking.<br><br>is that incorrect?<br><br>you can get USED spots for around and even under $100<br><br>you DO need to 3 axis gimble mount them. they only work of &quot;points&quot; up at the sky :-) if its upside down it will not work.<br><br>but again when I was looking at this a micro trak was a LOT more money. $300 is really not bad.
Very complete Instructable! I've been interested in launching a high-altitude balloon for a while now and have perused various sites on the web for hints and inspiration, so I appreciate the work that went into this Instructable. <br> <br>One question though--I thought that FAA approval wasn't required if the payload was below a certain weight. Still a good idea to contact them though. <br> <br>Still hoping to get things together and hoping for the price of Helium to come back down to Earth!
The world is running out of Helium for ever, most of the wastage goes in helium balloons like yours. Without Helium, MRI (Magnetic Resonant Machines) machines in hospitals will not be able to function as they need liquid Helium in a closed circuit cooling supply. <br> <br>Pure Hydrogen is used for met balloons and could safely be used providing the balloon is inflated and launched remotely in a open area. Just google 'Remote Weather Balloon Launcher'.
Uh, really? You mean that a party space balloon is going to collapse the birthday, event and helium balloon industry along with destroying our ability for better health? Even the continued distillation from the vast quantities of newly discovered natural gas along with the resultant producing outcome from uranium radiation will not keep up with this youngman's and others scientific explorations? And leave the planet void of vital helium? Wow! Whooda thunk? <br> <br>I'll keep worrying about the ground and continue recycling....... :) <br> <br>Good Instructable!!!
The amount of Helium that is found alongside Uranium ore is dependent on geological factors and the amount is very minimal. <br>Helium derived from natural gas or oil is only as abundant as the supplies of the crude product, which as you may know is running out as well. (newly discovered natural gas fields??? Where???)<br>The price of Helium has quadrupled since 2004 due to demand exceeding supply. If people want to play with balloons and talk funny then expect to pay alot more for it.
Prices risi.g because of false rumor and they can. I've traded and do not take to panic but, sense. <br> <br>New finds? One is, if you listen to rumor it could be one of the biggest is Marcellous (spelling?) Shale in NY, OH, PA, WV. There is reports of another bigger (?) in the mid-west, more in Canada and the government is focusing, as well as business on exploration within the states, finally. One cause, use, excuse for rumor and false commodity imflation, or real is to motivatve private industry to produce. Greed is a mighty motivator. But, if a shortage CT is in use and more technology everday to replace current old stuff. <br>Anyway, I applaud the youngman and I do conserve and try to be aware too. So, I thank you for more news an insight.
I didnt realise that ! <br>I knew that the Hindenberg had to use hydrogen because the US wouldnt sell helium to Germany ( at that time ) <br>Until recently we had the biggest franchise of steak houses here in South Africa giving away helium baloons to kids ! I can't say I have seen them lately though..
&quot;We're making space more American. We're making space more democratic. We're making space more available, approachable and real to the average American.&quot; <br> <br>If space is American, does this mean that I have to ask permission from the FAA to launch a baloon here in South Africa ? <br> <br>England thought once that it could rule the world, and there was a Boston Tea Party :-)
:) It was just a reference to making space more accessible. I'm not sure what the rules are in south africa. Good luck
just kidding, it did sound bit pretentious !
What was the total cost of the entire project?? Thanks! <br>
Wow good job! I watched your video before reading the instructable and thought things like, &quot;good thing an airplane didn't hit that&quot; and, &quot;oh no! terminal velocity is going to hurt on the way back down&quot;. Then, I realized that you contacted the FAA, made a parchute, tracked the balloon. WOW!!!
Very cool man! a few notes. you don't need FAA permission unless you go over 4 pounds. you only need to notify them not ask permission. <br> <br>the timelapse is great !!! nice to see some higher quality pictures on one of these. VERY nice.
You should have to morals to at least file a NOTAM (notice of airmen) to prevent collision.
You misunderstand or I was not clear. <br> <br>A NOTAM is not permission. its simply what it says. A Notice TO airmen. nothing more. I give notice all the time for our Rocket Launches and of course they have the OPPOSITE of the intended effect ie they DRAW airmen to the area who are curious and they get annoyed when we don't fly not realizing WE ARE NOT ALLOWED to launch a rocket while they occupy our airspace envelope so all launching ceases till they leave :-) hehe <br> <br>you ARE required to inform the FAA and that process &quot;WILL&quot; result in a NOTAM. <br> <br>but that is not permission. that is simply notification. an understandable requirements when in an advanced society where the airspace is heavily used. ie they can not tell you &quot;NO&quot; without cause. you are simply &quot;informing&quot; them so they can be aware of it and so the NOTAM can be filed for pilot safety. <br> <br>but its important to understand the difference between NOTIFICATION a reasonable societal requirement and &quot;PERMISSION&quot; ie NO you may not do this unless &quot;we&quot; say ok. <br> <br>the difference is pretty critical in the long run.
robotkid249, <br>Sweet job on the launch and nice instructions! I hope this helps more students get their projects to the near-space environment. <br> <br>regards, <br>Ben <br>www.ProjectAether.org
Why can the rope not have a break force of greater than 50 lbs?
FAA rules in case your payload goes into a plane. it can get chewed up easily, I guess.
Did you enter this into the Hands-On Learning Contest? If not, could you?
I did and it should show up in the contest page. it's awaiting moderator approval. Thanks for the encouragement!
wow wow wow. awesome video, awesome photos, and documentation!
This is so, cool.
Yowza. Congratulations! Is the horizon picture taken from your balloon? If so, you really should say so. And please put up more pictures -- several of your steps have the &quot;no image&quot; hand, because just videos don't count.
About This Instructable
88,517views
341favorites
License:
Bio: I'm 17. I enjoy making cool stuff, and promoting the "maker" community. Vote for my space balloon in the hurricane laser contest and hands ... More »
More by robotkid249:My Space Balloon: Project Stratohab Success!! High School Student's Budget Electricity Generating Kite! Wireless Power
Add instructable to:
