My T.A.P (Tactical Assault Pistol) Knex Gun
3,433
4
26
Posted
Introduction: My T.A.P (Tactical Assault Pistol) Knex Gun
This is the first pistol i have designed myself so suggestions would be good. The TAP is a very good pistol with a true trigger. 1 rubber band = about 5 feet in range depending on where you attatch it.
Pros: Sights, good handle, and good range
Cons:Sometimes need to ram ammo down the barrel
Ammo:Blue and Red rods work best
Credit to Knex_builder_freak for the handle
Step 1: Handle
build the handle
Step 2: Trigger
a very simple trigger
Step 3: Barrel/ Frame
build the barrel/ frame
Step 4: Ram Rod
build the ram rod
Step 5: Put It All Together
build it
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
  • Gluten Free Challenge
27 Comments
what kind of pieces should i use
2 more cons :
1. no mag
2. single shot
well technically its 1 con cos they're the same
my trigger was so powerful the firing pin almost went with it!!! 80
Too much glare.
 I made one exactly like that with a different trigger!
Can u explain the triiger how does it go in and why does it look different then the one in step 2
When you put it in, you have to insert the white rod first, then snap it in. you turn it around
