My device not collect "radiant energy", it collect static electricity I just wanted to keep the name given to it by Tesla.
I explain how I built it, the results that I obtained. I hope that someone can improve it and get better results
This is a presentation video with a brief explanation of the operation at the end, follows the full explanation and test results on this Instructable
The collector in aluminium collects the electrons of the air ionized, it work even with the passage of the clouds (if the air is dry), reached a sufficient charge it spark on candle and circulates the current in primary high-voltage of a injection coil, the secondary is connected via a diode and a small condenser, the small instruments notes the achieved energy.
Remove these ads by
Signing UpStep 1: Equipment required:
an ignition coil
a spark plug
a plug wire copper
a diode (general propose)
a capacitor 100nF-10uF not critical
an analog voltmeter
a support with a VERY high electrical insulation to support the aluminum foil (glass, ceramics ,plastic nylon wire)
Visit Our Store »
Go Pro Today »
the spark system and step down transformer needs to set up for one megahertz
Happy calculating.
yes I kind of been thinking about this for a while OLO.
and hope to prove it some day.
Hello guys, I am very fascinted of teslas research.
About radiant energy let clarify like this : According tesla all are the same radiant energy - cosmic rays day/night 24/7 - Aether(power source of his car)-static electricity - all it is considered one and the same but wothin different names.
I was watching some videos on youtube about this as well and was thinking why there is low voltage output from this unit . I figured it out finally , it is in material. Instead of metal plate try use some limestone or asfalt material. Please see this short article http://en.wikipedia.org/wiki/Low_emissivity . MEtal material does not absorb much of that radiant energy. But limestone,asfalt absorb far too much of this energy. And as well I would suggest that that antena would not be plate as rectangle , but best solution to catch lot of tat energy would be BALLL type antena - diameter 20 -50 cm or Pyramid type antena with base lenght 200 - 50 cm . In these two cases radiant nergy/static electricity would be harnessed in more eficient and much more faster way . Please also refer in google in electrical performance of limestone/asfalt etc. I am trying to figure out more of bulding this antena. For capacitor I would suggest 50 - 100 V , very hign capacity - mikro, nano 10 000 farrads at least or if possible more according tesla considerable electrostatic capacity. Tesla also stated:dielectric of condensator should be made the best quality of mica means will add a bit more on price for it has to withstand potentials that could rupture a weaker dielectrictric . SOrry if there i something wrong , but i am trying to solve this patent as well as you guys and it is my opinoion. Please write me anytime wou would clarify . I will be pleased tp answer. GOt lot of books about tesla, god good booksof radiant energy where everything is explained about ho that energy is absorbed,reflected and emited , also explains materials for radiant energy.
Thank you so far .
hope soon we will be powering our houses .
Tesla's site shows him powering a bunch of light globes! How did he do it?
Try with separate gruond, not in the wall.
you can get only few volts.
http://www.teslatech.info/ttstore/articles/york/esv1n4.htm
another idea is to use a conductive gas (dunno if it will react with the latex) that is lighter than air, then tie the baloon off with a wire inside it.
The fact is, rarely has anyone dealt with electrostatics in physics to explain the universe... everyone has thought since JJ thomspon's experiments that the main interactions in the universe are gravity, and electrodynamic modes. when electrostatics (or plasma discharge) is how nature interacts. The sun does it. when we touch a door knob while statically charged, we do it. Finally, atoms do it. (bees do it.... even edjucated fleas do it.) <-- joke....
but yes, a crt does act like a capacitor, infact tesla's experiments prove this. If you were to take a blown bulb and coat the inside with some kind of phosphorescence, and create a mini crt tube with no drain tap, you can build a static charge in it and eventually the glow will fade. This shows the full capacitance has been reached. Remember, electrodynamic waves (light) only produce when static charges are acellerating (charge redistribution).
Tesla showed an experiment where he put a thick coil around a lightbulb and sent AC through the coil. What he saw was an electrostatic effect illuminating the coil. Here is that article (you have to pay for the version that has the pictures..... google lets you see some of them in the book preview. I wish this was public domain... tesla would have wanted it to be.)
http://www.rastko.rs/rastko/delo/10761
