Step 2Power and Ground Buses
All you have to do is unscrew the breadboard from the backing, if it has one. Then cut away a strip of the foam backing with an Exacto knife. Next, solder the power and ground buses with some fine wire. Then cover with tape and screw it back onto the backboard.
I've intentionally removed clips, before. So I can tell you they are wedged in there pretty tight. You CAN push them out from the front, using a needle vice. But I bet you can't pop one out with a jumper wire (or a needle) using just your bare hands - meaning no pliers or thimble!
(If you ever really want to remove one, it's a lot easier to pry them out from the back using a small jeweler's screwdriver. :))
Using this strong flux, I can get away with bad soldering techniques, like picking up a blob of solder and transferring it to the fluxed joint. And things that would normally take 4 hands can be done with just 3.
The main thing to watch out for is that it's conductive when wet. If you use too much and leave excess residue on your circuit, it will cause problems if it gets wet (and it's somewhat hygroscopic to make matters worse). Luckily, it's water soluble, so it's usually pretty easy to wash off when you overdo it. But you have to take care not to get too much of it underneath smd parts, or it might be impossible to get to.
I use a small syringe or the tip of a broken Q tip to apply it sparingly. When working on ferrous metals, I wipe them with a damp cloth immediately afterwards.
Also, why solder don't stick to aluminum? Is it because of its strong oxide layer?
Nothing a bit of IPA can't remove though ;-)
PCB Police Electronics Forum - Try our competition!
