3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My Horizontal Axis Wind Turbine
  • last photo ←
This wind turbine was made mostly from a dismantled photocopier including the 2 big motors and gears.
The turbine produces 12Watts at 10-16v normally(wind10-20km). When the wind blows a little bit more(20-25km/h) it can produce over 20watts of electricity. i use it to charge 1 12v car battery of  20amphour. It takes about 15-19hours to fully charge the battery. at night i connect my battery to 12v fluorescent light bulbs (3 in total using 36 watts which i salvaged from a bus graveyard,
Power of WIND TURBINE: 12-22W
RPM of motors at a speed of  about 15km/h: 400-600rpm
RPM of Blades at a speed of  about 15km/h: 130- 200rpm
Max voltage produced: 14-16V
Gears ratio: 1:3
As for the charge controller, it is still beta.
4 comments
May 29, 2011. 2:22 PMBtheBike says:
Awesome Reuse Arjoon .
Apr 28, 2011. 11:06 AMcolinlewis says:
Impressive use of salvaged parts from the copier.
One nitpick of the title - this is a wind turbine, but it is not a Vertical Axis wind turbine.
Apr 28, 2011. 12:09 PMcpotoso says:
Indeed, not a vertical axis... the axis is horizontal. Please fix the title.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:ARJOON
coilgun and high voltage lover. i like everything that make a good sound like an explosion and gun fire as long as no one is harmed. living in mauritius where everything is so e*xpensive. Going t...
more »
