My First Knex Gun
1,066
Published
Introduction: My First Knex Gun
About: Hi everyone! I'm Aleceatsfood also know as Alec. To start off I've been a knex'er for quite some time. Although I've come up with dumbsquat for knex, I've built many things. I'm done with knex and moving on...
Hi everbody, this is my first knex gun post and its a mod of the noisy criket this gun uses blue rods as ammo.
pros:
-hold alot of ammo
-range 15-25 feet depending on bands
-not too heavy
-usually never jams
cons:
-not too sturdy
Credit to Big Z and Repton3
THANKS! please rate and subscribe
Step 1: Handle
this comes from the noisy cricket but is a little bit longer
Step 2: Body
this is pretty simple just follow the pictures
Step 3: Trigger
i know this is blury but if you cant figur it out look at the noisy criket same trigger
Step 4: Mag
ok almost done just finish up the mag
Step 5: Put It Together
just put the handle and trigger on
Step 6: Loading and Firing
simple. the rubber band goes inside the mag so you dont need a mag pusher.
Thanks hope it works well for you!
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    19 Comments
    The gun isnt bad but its not great i think u can do better. Keep maken guns
    This is great. I encourage you to build more.
    its good but i reaplaced the bullets for bleu rods so it shoots further
    but its very good for secondary
    sweet thanks!! I hope you like it and it works well for you! =D
    nope.
    Do you really build anything?
    r u asking my or knex gun builder?
    Seeing as it was a reply to knex gun builder...
    i have a new concept gun thats epik!!! pics will be up ASAP.
    With only 5 connection points between the mag and the rest of the gun, it's not too sturdy.
    Also the trigger is blocking the barrel too far up the gun, and that handle was not meant for guns like this.
    yah the handle is ment for a mag but i just decided to use it
    mag is a little bit to BIG but repton's rebular mag is good and i think it is a pistol
    with a mag... and nice idea for a gun
    thanks! and yah you can make the mag any size really
