3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My first hydroponic set
How to make a foolproof and cheap fully working hydroponic system.
This system can be used indoors or outdoors, can be used as a cloner or to grow veggies and plants.
This is the first set I build, 5 years ago.
It is still perfectly working.
Step 1List of materials
List of materials
A blue Rubbermaid tub, or any other brand with an inside rim.
The inside rim is important, as the PVC tubing will rest on it.
1/2 inch PVC tube
4 pieces 1/2 inch PVC tube 90 degrees angles.
one T junction 1/2 inch
an aquarium pump
a 15inch long flexible water hose 1/2 inch diameter.
6 or 8 empty yoghurt pots
a 24 hour timer
29 comments
Mar 23, 2009. 4:53 PMDELTAWOLF05 says:
way don't the roots just sit in the water, eliminating the need for a pump? sorry im a hydroponics nube trying to make a first rig
Jan 15, 2011. 5:34 PMa.murchie says:
Another reason to keep the roots in circulating water or a drip or mist is simply that they must have oxygen to live and grow. Too much water and with few exceptions, plants will drown.
Apr 13, 2009. 5:32 PMDELTAWOLF05 says:
ok so i built a rig close to this the diffences being the the pvc sprayer but they r only minor. will miracle grow work as a fertilizer and how do i prevent the roots from roting?
Jan 29, 2009. 4:30 PMevengravy says:
you would be far better replacing the lengths of pvc tubing with black poly tubing, this way you could attach 180 degree misting or fogging nozzles for full coverage. These misting nozzles are cheap and easily available, you simply Insert the heads into the 1/2" Poly-tube by punching a small hole then threading on the heads. The heads can then be adjusted so that their spray will cover the entire area.
Either this or have pin sized holes in the pvc for increased coverage, this can be achieved by heating up a darning needle till its red hot and piercing the pvc tubing. Your current water pump is not strong enough to supply such large holes in the pvc tubing.
sorry to be so negative, I build hydroponics for a living, it would work ok as it is, but these small changes would make it great and cost little!
my two cents.
Jun 11, 2010. 9:36 PMbotronics says:
PVC is better for use with micro spray heads. You drill and tap for 10-32. Thats what I did on mine. The pvc on the outside spraying toward the inside is great. This prevents spray from hitting the lid edge and dribble outside along the lid top. I placed my spray heads in the middle and sprayed out toward the edge. I had to make a spray barrier to keep it from dripping outside the container. I suppose some weather stripping would seal the top, but I had trouble with it sticking with all the wetness. A filter bag and polyfill batting around the pump will keep the heads from clogging and protect the pump.
Jun 11, 2010. 9:15 PMbotronics says:
I just built a system similar to yours. Planted seeds and the lettuce is just starting to come up after 5 days! I'm using VF-11 for the neuts. That stuff has crystals coming out of solution and about 2 tablespoons full of solids in the bottom of the bottle. I divided the solution between another gallon jug and added water to dissolve the stuff. It helped, but not completely. Go here to see the setup.
Jun 15, 2009. 4:20 PMruss960 says:
Chefmichel I used your article to build my own unit. I started with plant purchased from Home Depot. I cleaned them free of dirt and such and planted them. I have them in Hydroton clay pellets. I had them set to water 5 times a day 30 minutes. My leaves are drooping any ideas? My pots appear to be drying between watering but are getting saturated and my clay is getting saturated. Anyone any ideas?
Jun 21, 2009. 5:14 PMtruestyeloutlaw says:
It could be because they started out in dirt and you moved them into hydro, that or you don't have any nutrients in the water
Jun 22, 2009. 6:04 AMruss960 says:
I have nutrients but found I was giving them too much Texas Sun. I have relocated the system and they are doing well. I've even got a pepper started coming in. Thank you for the advice.
Jun 17, 2009. 11:25 AMruss960 says:
Chefmichel, I think the Texas heat is my issue. The spot I had the seedlings in had only partial day sun and the new spot has sun most of the day. I also have it in a place where my sprinkler hits it also. I'll look into the PPM and PH. I've noticed it looks better every morning. I may be just nervous as I'm new to this. Thank you for your advice.
Apr 8, 2009. 1:25 PMzachpower7 says:
TO CUT THE HOLES TRY USING A BOX CUTTER WITH A SHINGLE CUTTING BLADE. ALL YOU WOULD HAVE TO DO IS START THE HOLE AND THEN YOU CAN JUST HOOK THE BLADE INTO THIS HOLE AND TRACE YOUR CIRCLE. LESS LIKELY TO CUT YOUR SELF IF YOU ARE SMART ABOUT IT
Apr 21, 2009. 9:46 AMWhiteTigerTails says:
Caps lock.
Apr 7, 2009. 9:05 AMsurfguy1936 says:
For those who asked about the pump the best pump to use would be a 400. anything less than that for this size system will work like a 250, but it risks the chance of getting clogged. And another thing i would put the 360 mister sprayers on the pvc and put it across the tub not around it, just to get better water coverage
Mar 31, 2009. 11:06 AMwilson.joe says:
I went down to lowes here and got all the parts, I ran down to the hydroponic store and picked up the pump and some nutes and pots.. and I didn't have the whole saw, which I thought was a bit pricey , but i can use it again for other projects :D thats the wonderful thing about tools..
Apr 2, 2009. 8:59 PMwilson.joe says:
without the price of the whole saw.. lol.. lets see.. the tote cost around $8 at biglots,the water pump cost around $25 at local hydroponic store, the pvc and corner pieces came somewhere around $5 but I got extra pvc. so that comes to around $40 roughly.. oh the net pots cost 75 cents each.. yeah around $40.. not bad compared to some setups, or buying them premade. 1/2 the nutes.hmm...You know in some systems like simplified non circulating hydroponics the nukes may never get changed. no pumps at all and some grow cucumbers out of a garbage can.. gradually the roots suck up all the nutes,but as long as part of the roots are getting them the rest do okay just hanging in thin air..
Mar 30, 2009. 9:51 AMcementbrains says:
I started with a system like this a few years back it works great but the small jets always seemed to plug up on me over time . So eventually i made them twice the size and they worked great .. best of luck to you..
Mar 29, 2009. 2:36 AMwilson.joe says:
I'm going to do something similiar possibly this week, im in a hurry to get things going hydroponically.. problem I see with your corner cups is that they are not going to get much if any water at all because of the 4 pieces of 1/2 inch PVC 90 degrees angles. unless you also put holes in them too. being white I can't tell if you did or not.. but I don't see water coming out of those in the pics & where did you get green PVC? and what exactly did you use to cut the holes? a hole saw? being there only one lid I would be afraid of messing it up.
Jan 30, 2009. 4:43 AMevengravy says:
Actually that is a large pump for such a tub. I know what you mean about clogging nozzles, this is a frustrating and difficult factor to avoid unless you use reverse osmosis or other highly filetered water. Which can become expensive to the average experimenter. Even the more expensive nozzles suffer with this problem to some degree. One way to reduce the possibility of clogging is to have the nozzles pointing downwards, but this is not possible in your design. The simplisity of the system is to its advantage in regards to maintenance and the waterfall effect you have going there is very advantageous as it increases diluted oxegen levels in the solution and also helps to promote plant benificial baterium in the system (similar to bio-bucket systems if you're interested) maybe you could experiment with putting some lava rock in the solution also, to further harbour this bacteria, you will surely notice the difference in growth rate and it will do no harm to add it. Also have you thought about water temps? its fairly easy to add a submersible aquarium heater to keep these in check. one other note on cutting the planting holes: try using aviation tin snips, easily available cheap and go through rubbermaids like butter.
Jan 24, 2009. 7:27 PMashmist says:
Whats the timer for? How long do you need to run it for?
Jan 17, 2009. 11:32 AMwiley coyote says:
Simple and effective. Nice. Cutting the holes in the lid sounds rather treacherous.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:chefmichel
