3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My home made solar cell step by step
Here is a low power low efficiency photovoltaic cell that you can make you own in the kitchen
with materials from the hardware store.
This cell is made from cuprous oxide instead of silicon and you can build a working solar cell in 2 hours
to build it i follow this instruction: http://scitoys.com/scitoys/scitoys/echem/echem2.html
on
Step 1Materials you will need
A sheet of copper flashing from the hardware store
A transparent CD case
Electric wire
Sodium bicarbonate or Table salt
An electric stove
hot glue
solder
Sheet metal shears for cutting the copper sheet
I suggest you visit http://scitoys.com there are many projects and interesting kit
153 comments
1-40 of 153next »
Apr 29, 2012. 6:15 AMlilbeezy says:
how can you get the copper sheet
Apr 21, 2012. 4:01 AMlilbeezy says:
help me to build solar Panel and i want to know how it made
Feb 15, 2012. 8:50 AMVishvesh says:
is it compulsory to seal the CD case and to glue the copper plates ?
Feb 2, 2012. 3:17 PMloose thread says:
i tried to solder the wire, but it wasnt working, how do i do it? do i use soldering wire?
Jan 13, 2012. 5:29 PMloose thread says:
does this cell produce the same amount of energy a cell in the actual solar panel?
Dec 17, 2011. 4:34 PMloose thread says:
are you 100% sure that it will work?
sorry, but i am doing a science fair project, and i am stressing out
Nov 13, 2011. 2:41 PMzking3 says:
question.... how much salt would you put in the solution??
Oct 13, 2011. 1:10 AML'0@ says:
Can we use any other material in place of copper?Or can we use a copper wire?
Jun 15, 2011. 3:33 AMhemanath says:
I want to know how silicon solar cells are manufactured
Jun 2, 2011. 3:44 AM21ali2ali1995 says:
i hope it will work. i will try and tell u.
i have a question . can will built a pannel by joining many cell like this one ?
and
how much electricity it can produce?
Apr 12, 2011. 5:21 PMbubbachr says:
why cant you let flame contact the copper
Mar 30, 2011. 10:05 AMmanny6967 says:
Thanks for the info I'm gonna try it and post my results..
Aug 26, 2010. 5:09 AMIvraine says:
Hey, I've seen this project before in a book in our school library. I believe the original project called for something along the lines of silver nitrate? It said it could produce about 4x the amount of power as yours, but it needed carcinogenic chemicals, high-power acids, and lots of money. Great project though, I liked that you didn't need to make a more complicated solution.
Aug 12, 2010. 5:52 AMki-rou says:
sir can i make many of this solar panel and then connect them to each other like a battery? ,, and if i can how many of this solar panel should i make for me to be able to power a small light bulb used for toys?
Aug 11, 2010. 6:50 PMnatester632 says:
There's 11 minutes left and there isn't any black
Aug 11, 2010. 6:43 PMnatester632 says:
Mine started forming white-ish spots, is that normal???
Jan 3, 2010. 4:02 PMJaif14 says:
Is there any way to cook the copper sheet on a gas stove?
Aug 11, 2010. 6:18 PMnatester632 says:
Put it in a pan
Aug 11, 2010. 6:11 AMki-rou says:
how many of this should i make for me to be able to power a small dynamo usually used for toy cars? pls answer.
Jul 10, 2010. 7:14 AM100389 says:
do i nee to cook the other sheet of copper? just asking..thank you
Jul 11, 2010. 9:22 PM100389 says:
thank you
Jul 8, 2010. 10:40 AMCrazy-Inventor says:
can you please explain me how does it work.
Jul 10, 2010. 8:55 PMCrazy-Inventor says:
My doubt is how did the cooked copper plate become positive and the other negative terminal. Which is the anode and cathode??
Jul 10, 2010. 8:54 PMCrazy-Inventor says:
I made this as my Physics experiment and i got full marks. Thank you
Jun 7, 2010. 11:04 PMCrazy-Inventor says:
hello mr. Alessiof i got a thick piece of copper will it work?? Thank You
Jul 8, 2010. 10:39 AMCrazy-Inventor says:
can you tell me why should we heat the copper. or what happens me when copper is heated.
Jul 5, 2010. 2:32 PMrensatoshi says:
Is it really necessary to use an electric stove? or we could just put it in a pan over a gas stove.. just asking
Jul 14, 2009. 6:42 AMstrmrnnr says:
Just wondering if you can use two large pieces the same size with a small gap in the case. Or, do both pieces have to see the sun for it to work. Side A would be the shiny copper and side B would show the oxidized copper.
Jul 15, 2009. 7:41 PMstrmrnnr says:
I added a drawing. Would this work better or do they have to be side by side?
Jul 5, 2010. 2:48 AMgapl says:
hi it is nice idea can you please explain the idea to me. It would be very helpful
1-40 of 153next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:alessiof76
