3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My home made solar cell step by step
Step 7Test the cell
Test the cell
test the cell whit Sunlight
A note about power
my cell produces 58 microamps at 0.10 volts.
Don't expect to light light bulbs or charge batteries with this device. It can be used as a light detector or light meter, but it would take acres of them to power your house.
15 comments
Aug 26, 2010. 5:09 AMIvraine says:
Hey, I've seen this project before in a book in our school library. I believe the original project called for something along the lines of silver nitrate? It said it could produce about 4x the amount of power as yours, but it needed carcinogenic chemicals, high-power acids, and lots of money. Great project though, I liked that you didn't need to make a more complicated solution.
Aug 12, 2010. 5:52 AMki-rou says:
sir can i make many of this solar panel and then connect them to each other like a battery? ,, and if i can how many of this solar panel should i make for me to be able to power a small light bulb used for toys?
Jul 8, 2010. 10:40 AMCrazy-Inventor says:
can you please explain me how does it work.
Jul 10, 2010. 8:55 PMCrazy-Inventor says:
My doubt is how did the cooked copper plate become positive and the other negative terminal. Which is the anode and cathode??
Jul 10, 2010. 8:54 PMCrazy-Inventor says:
I made this as my Physics experiment and i got full marks. Thank you
May 10, 2010. 11:02 PMCrazy-Inventor says:
Hey Can u plz teel me what size this should this solar pannel should be to light a bulb or to run a R/C car. Thank you....
Feb 28, 2010. 10:37 AMclemjon says:
can i use it as a substitute in solar panel?..if so, how? if not, can you please advice some?
Dec 4, 2009. 4:10 AMphmanzano says:
 Hi Alesio,
There is a Grätzel cell project based on chlorophyl you might be interested to join, see www.togethearth.com
May 5, 2009. 10:52 PMJohnbars says:
Hi there my friend. Can this power up a small radio or a walkman device? If not, then how big must it be to power up such small devices? Thanks so much....
May 7, 2009. 9:47 AMbart416 says:
Really depends on the way the radio is built. An old fashioned radio, very unlikely. New electronic ones without displays, shouldn't be that much of a problem if you hook up a few.
Jan 3, 2010. 3:50 PMJaif14 says:
im not sure if this is true, but i think there is some titanium dioxid in some types of white paint.
May 7, 2009. 2:28 PMjeffreycb says:
what are these cells that deliver 5 to 10 times more voltage? I want to learn about the different other designs. what is "Graetz cell"
May 7, 2009. 5:35 AMJohnbars says:
Thanks!!! This is great info for me!.....more power to you!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:alessiof76
