My New Guns
740
Published
Introduction: My New Guns
About: I'm an intermediate knexer who builds replica guns and performance guns. If you would like me to make a replica of a gun, just ask. If you would like me to build your gun and review it, just ask. My gamertag...
Credits to oblivitus for the adjustable range rifle and non-interlocking rods ideas.
So yeah, these are my newest guns. They are both very powerful. The 1st gun is a crossbow sniper on thetop, and a pin gun on the bottom. The pin gun has a yellow rod, 12 shot, non interlocking, internally fed , fixed mag. It also has a true trigger, and a pin guide. I call it the Mag-Bow. Second gun is a shotgun pistol.
    • Oil Contest
      Oil Contest
    • BBQ Showdown Challenge
    • Water Contest
      Water Contest
    25 Discussions
    Its when the rods dont lock into eachother. Like a bolt action, except without the second firing chamber.
    Mind telling us how that doesn't happen?  Because it's happened on pretty much almost any mag fed gun I've made.
    They enter the mag tilted, and the mag is tight, so they cant be straight. the pusher applys pressure in just the right place so only one round enters the chamber at a time.
    That doesn't make sense.  The mag on your gun is perfectly vertical.  The pusher part seems logical if you use a wide mag pusher like on the ZKAR.
    The front and rear mag walls are closer together than the length of a yellow rod, so they won't fit in the mag unless they are tilted, I believe.
    In that case, no.  If you tilt the round, you are actually making it wider than if it was horizontal in a position where it's likely to lock.
    I happen to agree this isn't the best mechanism, I was just clarifying what he meant for you :).
    Agreed.  Have you seen my attempt at a bolt action?  I don't think It's come up on the Recent page yet, but if you go to my profile it should be there.
