This is a more reliable Stirling engine generator that I built. It has a graphite piston and a larger cooling tank, so it will run all day powering the radio. The displacer is steel wire wool. I haven't measured it properly yet, but I think that it's slightly more powerful than the first one I built. This one will just about run the radio on one candle, although it really struggles with the LED's using three candles. Photo's will be available soon on my site :
http://sites.google.com/site/reukpower
Imagine how much power you could produce from a 1 gallon paint can sized Sterling engine....that would be cool to see...hint hint
I do plan on trying out a coffee pot Stirling engine sometime!
Thanks!
Very nice (good sound too)
L
- Stronger bearings, I used M6 bolts cut down with a 2mm hole drilled in them]
- Graphite power piston
- Much taller to accommodate said piston.
- Uses a 22mm pipe elbow to attach the piston
- Steel flywheel from large beans tin
- Big water tank
To attach the power piston, I used a 22mm pipe elbow superglued to the side of the can then sealed l all around it with RTV silicon , seems to be airtight. The piston cylinder fits in this and is sealed again with RTVAny air leaks would show up immediately because the cylinder is under water too :)Sorry I missed your post for some reason.
