My Solution Regarding Max Aperture When Connecting a Lens on a Sony Alpha Camera With a Reverse Ring (mount)
Published
Introduction: My Solution Regarding Max Aperture When Connecting a Lens on a Sony Alpha Camera With a Reverse Ring (mount)
Sorry for the bad English, it's not my first language and it was 04:00AM, so sleepy.
WARNING: WHATEVER I DID IN THIS VIDEO (Leaving the camera open and using a razor to carve) IS TOTALLY UNPROFESSIONAL AND NOT RECOMMENDED. IF YOU HAVE A BETTER WAY TO DO THIS, PLEASE DO.
Anyway, one problem I found when connecting my lens on the reverse ring is that the aperture is set to max which requires more light and doesn't give the picture I want (Close up with low aperture).
My solution is to use a spare lens back cap, carve the inside
and keep the latch that keeps the aperture open so when I screw it in, it opens up the aperture.
I'm sure I'm not the first neither the last one to come up with this solution, but I haven't done any research for it and came up with it while pooping after having a double cheeseburger (Sharing alot?)
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    Dear Loolykinns
    Does you have that problem (no lens attached shutter is locked)
    If you have this problem , try shooting using the manual mode (M ) on your camera mode.
    Ali Wafa
