3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My tube! Stereo sub woofer speakers for i-pod and mp3 second version(with batteries and USB charger)
My quarter realization is a complicated more of precedent but it is not null of difficult to realize.
Draft of two self powered cases stereo to batteries reloadable with possibility to recharge the i-pod
through a taken USB fed from the same batteries.
These can be very useful in camping,to the sea and also in house for being free from cables of feeding.Regarding the form me it appealed to this form 'post modern'.slender as if the cases of residual the war ones were penetrated in the land,or, however they gave that sense of accidental that it appeals to me.
Step 1The tube
The tube
The container consist in a  P.V.C.heavy tube.
In order to create the slender form I have executed a cut of 45? ,with the aid of one level laser (but it is not sure the only possible way).
11 comments
Mar 4, 2010. 10:54 PMajparag says:
congratulations for successfully completing your instructable. i really like it.
i want to know how can i get an amplifier like this which works on DC power. what are the sources other than a portable radio? if u can solve this problem it will be gr8 help.
thanks!
Mar 7, 2010. 1:33 AMajparag says:
i want to know where did you get this circuit from? can u post a picture of the radio or can u elaborate more on it?
i dont have such a radio at home so i want to know from where can i get an amplifying circuit.
Sep 22, 2009. 12:41 AMBerserk87 says:
lots of pictures, lots of detail, includes schematic for wiring, and a nice looking results. 5/5. I was expecting another guide on how to solder a headphone cables to a speaker, and not use an amp.
Sep 22, 2009. 3:46 PMBerserk87 says:
there are two suggestions i have if you plan on making a new/improved version. 1. lithium ion batterys, they cost more then normal batterys, but they can put out more power and they have much higher capacity. 2. your 5V regulator (the LM7805) could be replaced with a buck regulator. the LM7805's waste the extra power you have as heat, to get that 5V output, if you used a buck regulator (DC-DC converter) you could get ~95% efficiency. it would cost probably $7 instead of the $1 on the lm7805, but you could run your speakers for longer. if you included those two improvements im sure your speakers could run for a significant time longer, plus lithium ions can discharge a lot more amps than the other batterys, which means you could use a much more powerful amp for just as long :)
Oct 15, 2009. 9:04 AMDa Nugesta says:
you don't make sense did u use a translator???????? :)
Oct 15, 2009. 12:53 PMBerserk87 says:
torx : "I make excuses myself for my lame English."
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:torx
