3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
My version of a Table Saw
I needed to rip up a lot of timber for some roofing joists in my workshop. They were to be filleted into some plastic boards, so I needed to do them accurately. As a saw table would be around £90 minimum and probably wouldn't get used after the workshop was completed I decided to see what was on offer in Instructables. What I found was a number of excellent designs which used everyday workshop tools. As my workshop is still being built these weren't at my disposal. I have my trusty old B&D circular saw and decided to make a table out of laminate flooring. This medium is thin, so I won't need to router out a recess, I can just build the area around the saw plate up with further layers. It is very square and has a tough polished surface. I popped down to the local Homebase and found a pack that was damaged. The original price was £25 ($40) I got it for £13 ($20). An acceptable price for a temporary job. I also bought a NVR on/off switch as the saw trigger will have to be held open and under the table. The one I bought has a three pin plug in and out so no additional wiring is required. This cost £20 but will have many uses in my workshop.
So far I have used 1 pack of Laminated Flooring
                                  1 tube of no more nails fast grip glue
                                  1 No Volt Release on/off switch
                                  1 unsuspecting pallet
                                  1 load of 2" and 3" screws
                                  450mm 20mm square box  mild steel
                                  3 m6 x 90mm carriage bolts, m6 nuts etc
Step 1The raw materials
The raw materials
Before I start My 'able. A word on safety. I always use the relevant safety gear. Even then I have still managed to end up in the ER. Saws and electrical weapons don't often give you a second chance. Protect your eyes, ears and hands. The laminate sheets are MDF and prodice a fine dust when cut, so a mask is a good idea too but I was wearing it when I took these shots.
9 comments
Feb 24, 2012. 3:41 AMnanosec12 says:
I think it would/could be a bit safer if your 'blade' cut out made room for the guard to come up when you are not cutting. Looks pretty dangerous without a useable guard.
Feb 23, 2012. 5:27 PMyoyology says:
I need to do this in reverse. Can you post an instructable on how to convert a table saw into a handheld circular saw?
Just kidding! Great instructable. Love to see this kind of ingenuity mated with good sense and attention to detail.
Feb 22, 2012. 9:32 AMpfred2 says:
My version of this has a radial arm saw on the other side.
Feb 22, 2012. 5:01 AMvincent7520 says:
yes but how do you adjust the blade height ?…
Feb 21, 2012. 11:22 AMfeistydonut says:
Man do I need to do this. Thanks for taking the time to post this.
Feb 21, 2012. 10:07 AMembochner says:
great work, very cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:aideym(Aiden McHaffie)
I work on the railway and in my spare time I cycle, I do archery and I build things. I always look at things I want or need and then work out a way of making them myself if I can. Ok, sometimes it pro...
more »
