My Vertical Axis Wind Tuebine
5,707
128
10
Published
Introduction: My Vertical Axis Wind Tuebine
About: I am from Thessaloniki Greece! I love the world of electronics in every step of my life! I am electronic engineer and my hobby is my job!The summer of 2014 i'm raedy to begin my own company oramasolutions a...
The rotor consists of 16 neodymium magnets 30mm dia - 7mm height...
The rotor diameter is 30cm... The cylinder rotor holder has 30mm diameter.
The coils are made with 1.25 mm (18 gauge) magnet wire.... They have 140 turns with inner dia 20mm and outer 50mm.The height is 20mm.
the test are with 2 series of 8 coils in paraller... As you can see there are a lot of Amps with very few turns....
at 60 r.p.m. i have the following measurements:
12Vrms 1,8A the multimeter on Ac(not the peak value).
at 120 r.p.m. 24Vrms and 4 amps...
I think it is very good for my needings :)
Step 1: The Rotor
There are 2 layers.
The first is iron where the magnets are attached and glued.
This will increase the strength of the magnetic field.
The aluminum is holding the magnets in wright place :)
The bearings are the following in the pictures.
Watch the final schematic to understand the assembly.
Step 2: The Stator
The stator is made with 2 layers 2 for the same reasons the use of iron plate.
The liquid is polyester for waterproofing reasons.
Watch the harmony wiring coil and the final drawing to understand the construction.
Step 3: The Wings
Made from aluminum and plastic polyethylene.
hope you love it...
Please visit and share my arduino related indiegogo campaign too...
www.indiegogo.com/projects/usbeduino-the-arduino-project/x/6872674
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    10 Comments
    I sure hope I get a quick responce
    Hi trying to make mine. Having a little problem now. Built my stator 3phase, 3 coils each. I have three terminals. How to I convert these to DC current . 12volt.
    How much wattage it generated at different heigh/rpm?
    Very nice. You got my vote.
    I just want to let you know that you misspelled TURBINE in your title. Great Instructable.
    I bet you could enter this in the Home Technology Contest as well....
    Thanks for the mention.I missed that...
    I will give it a try....
    Excelente proyecto! Con todos estos datos a tratar de hacer algo similar. Muchas gracias por compartir su trabajo
    Excelente proyecto! Con todos estos datos intentaré fabricar algo similar. Muchas gracias por compartir tu trabajo
    Thanks alot my friend..
    from google translate:
    Excellent project! With all these data to try to do something similar. Thank you very much for sharing your work
