What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
On the second bulb, I cut away a small edge of the base. Just enough to grab it with needle nose pliers and start 'unwrapping' the base from the bulb. Shen I was done I ended up with a clean glass bulb.
Please tell me how you remove the base without breaking the glass bulb. I have tried this several times and because the bulb is a under a Vacuum Pressure it breakes and I have never seen one come apart at the base as clean as yours. I would love to know which brand you are using so I could make one Thanks Tom
I have bought cheap brandless bulbs and removed the foot as well (it was for another project). Just hacksaw through the lower end of the metal base and then just peel off the rest of the metal with pliers.
This leaves you with a closed glass bulb haveing a glass rod stick out at the bottom.
Break off that rod. Then immobilize a belt sander somewhere or ask someone to hold it for you and gently but firmly press the base of the lamp against the turning sandbelt,
Turn the lamp a few times as you probably will not push it sgainst the belt completely straight.
Very soon you will have gone through the base and the inner glass off the lamp will be loose and yr bulb will be open
Break off that rod.
