3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Intermidate air rifle with interchangable stock
This instructable inspired by irwinner's http://www.instructables.com/id/25MM-Pneumatic-Sniper-Rifle/  will show you a similar gun but still completely different.  It is relatively cheap and uses a modded sprinkler valve for a valve. It's an intermediate build and has some tricky parts to it so have at least some experience in pvc guns and that area. Ie's extreamly fun and entertaining to use when its all finished.
      WARNING: DO NOT ATTEMP THIS IF YOU HAVE LITTLE OR NO EXPERIENCE IN MAKING PVC AIR CANNONS OR RELATED THINGS. NEVER AIM OR SHOOT THIS AT ANYTHING LIVING THIS INCLUDES PEOPLE AND ANIMALS. I AM NOT RESPONSIBLE FOR ANY DAMAGE OR HARM INFLICTED TO PEOPLE OR PROPERTY BY THIS GUN. BUILD AND USE AT YOUR OWN RISK . ALWYAS BE SAFE WHEN USING THIS WARN BEFORE SHOOTING, CLEAR THE AREA AND NEVER LOOK DOWN THE BARREL EVEN WHEN NOT LOADED. TREAT THIS AS IF IT IS A REAL FIREARM
Step 1Materials & tools
Materials & tools
Here is a list of the tools and materials needed to make it. Some of them may not be available in some places but most of them can be found everywhere. Make sure all your pieces are pressure rated. For the sprinkler valve here is a link ,http://www.rotteneggsx.com/r3/show/se/212460.html. instead of using a 1/4" pipe fitting use the hose barb. Also you can just keep the solenoid in instead of using epoxy its cheaper.
Valves
-Modded sprinkler valve
PVC pieces
- 1' of 1 1/2' pvc
- 4' of 3/4" pvc
- 3 3/4" 90* elbows
- 2 3/4" 45* angles
- 1 3/4" Tee bend
- 2 3/4" caps
- 3 3/4"- 1 1/2" reducers- 1 threaded, 2 non-threaded
- 2 1 1/2" Tee's
- 1 1"-1 1/2"reducers(2 if you don't already have a barrel to use)
- 1 3/4" male adapter
- 1 1" stub out approx. 3" long
Miscellaneous parts
- approx. 2' of pressure rated tube   3/8" ID  1/4" OD
- 1 3/8" threaded 1/4" hose barb 90*( if you dont have this you can use a 3/8" by 1/4" hose barb, as long as it fits the tube)
-2 3/8" by 1/4" hose barb( if you dont have the part listed above)
-3/8" schrader valve
-air compressor blowgun piece
- 2 extra small hose clamps, to fit the hose
Tools
-drill with 3/8" drill bit
-teflon tape
-adjustable wrench
-flathead driver to tighten hose clamps
- pvc primer and glue
- vice
-something to cut pvc, hacksaw ect.
5 comments
Mar 24, 2011. 8:30 AMsaulsballz says:
hey were trying to make a shooter like this for a school project haha how much did this cost?
Feb 16, 2011. 7:44 PMDoctorOfAwesome says:
Your right, this is very beast. Not to be rude, but I think combustion cannons are better. They cost less and are easier to carry. and with all attachments, they are SO RAD. This is a great instructable and I would give you a patch (if I were a pro)
Feb 17, 2011. 7:38 PMDoctorOfAwesome says:
I added a reply to one of your questions for a tripod thing for your cannon
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:ostomesto
