3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
NASH Air Gun / Cannon
I've had a small fire extinguisher sitting around for a while and since I have more I decided to turn it into an air cannon. The acronym stands for "Nerf Air Soft Homemade" since it can shoot Nerf darts, airsoft BBs, paper rockets (with plastic bottle fins!), and whatever else fits in that wonderful 1/2" barrel.
Those of you who are older and have more sense in you can shoot AA batteries, but be aware: these can be lethal if they hit a person in certain places. NEVER EVER shoot at a person, animal, or something you don't want to damage!
That said, let's get started. Here's the shopping list (or parts list if you're like me and have a 30' trailer of pure plumbing parts ;-)
(1) Pressure Gauge: Make sure it measures from 0-100 PSI (or near there), has an air fill valve, and 3/4" threads on the bottom.
(1) 1/2" x 3/4" Brass / Iron Adapter (threaded of course)
(3) 1/2" Brass / Iron Nipples (about 2" - 4" long, doesn't matter)
(1) 1/2" Brass / Iron Tee
(1) 1/2" PVC Male Adapter
(1) 1/2" Ball Valve (metal, threaded ends)
(1) Small Fire Extinguisher
That's it! On to the build...
Step 1Disassemble the Extinguisher
Go outside, pull that pin, and enjoy emptying the extinguisher. Or have a weenie roast and then put out the fire with it. Either way, make sure it is completely empty.
Now depending on your extinguisher, you'll have to figure out how to unscrew the top from the tank. Mine had a metal label with a tab that I secured in a vise and then I used a wrench to loosen it. Turns out the one I have wasn't that tight. Not sure if they are all that way, but take courage! It will come off!
You can use a crescent wrench or channel locks on this guy.
22 comments
Jan 18, 2012. 1:39 PMGhostsniper1979 says:
it does but i fail to see the Nipple for filling, can you explain where it is
thats a funking sweet design by the way,
cheers
May 21, 2012. 1:43 PMAJMansfield says:
In this design it is at the base of the pressure gauge; its that little metal but that sticks out to the side. You may have gotten a pressure gauge that didn't have one, but that isn't that incredibly hard to fix: you can either get a new gauge altogether or just get a new fill valve to attach at another spot (you will need another 'T' piece too, and perhaps some more pipe for this).
Jan 23, 2012. 8:44 PMsjoobbani says:
I recentely made a fire extinguisher air cannon, but then I realized there might be instructables about it! so I checked, and I noticed that none of them use the existing fire exinguisher valve?!
WHY NOT?!?!?!!
My entinguisher's rated to 595PSI, so basically, I pressurize it
and unscrew the 'stock' nozzle, and screw on a barrel that has a T on it for "auto feed" so It's kind of full auto..
Feb 14, 2012. 7:03 PMsjoobbani says:
Sorry it took me such a long time to reply!!! I"ve changed up my design!
I didn't really like the 'auto feed' thing I had going on with the T, so I have a 'deep socket coupling' attached.
Feb 22, 2012. 10:53 PMsjoobbani says:
The trick is, taking your extinguisher into a hardware store, and trying to see which fittings fit the best. I added some JB WELD to it later on to make sure it's solid (like you can see on my pressurizing adaptor) but when I took the picture, it was just pushed down in there!
Jan 17, 2012. 9:04 PMGhostsniper1979 says:
how are you pressurising the tank?
Oct 23, 2011. 5:20 PMstevenh429 says:
and where would i get the pressure gauge like that?
Oct 27, 2011. 5:54 PMstevenh429 says:
Yes, i live in the u.s. , I go to home depot...
but where would I get the pressure gauge with the valve like that?
Oct 23, 2011. 4:36 PMstevenh429 says:
This is THE best instructable ever.
PS, what brand is that fire extinguisher and what kind?
Sep 8, 2011. 4:00 AMsithlil says:
how far do u think it shoots?
Oct 6, 2011. 10:48 AMdidgitalpunk says:
true it would just be stupid to have written on your friend's death testament "killed by a nerf dart" XD
Aug 31, 2011. 5:08 PMhifatpeople says:
awesome
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:godoggie(The Unread Publicist)
I'm a inventor, hacker (not a cracker!), lover of my free electrical and parts supplier, etc. I don't normally write bios, so you're lucky to get even this. TTFN ;-)
