NERF Alpha Trooper CS-12 Complete SWAT Guide
4,051
Published
Introduction: NERF Alpha Trooper CS-12 Complete SWAT Guide
Before I get started I would like to apologize for my absence on Instructables. This guide will show you how to make complete accuracy on the alpha trooper CS 12 nerf weapons including default Nerf, and Nerf Strike elite. For this instructable you will need the nerf strike alpha trooper CS 12 , the buttstock the Nerf N Strike elite retaliator, a hot glue gun, tape, and the suppressor/barrel extension from the Nerf spectra. Once you have these items you continue to modifying the weapon.
Step 1: The Barrel
The barrel step will add accuracy to your weapon to shoot farther and better. This barrel extension will hurt you anymore and make it a lot less work for you. To get the barrel on I use the hot glue gun to do the rim of the barrel that is already equipped on the Alpha trooper. Idenline a barrel extension up with the glue and put it on there I left it on there for about 1 and a half minutes. This is extra work but I would double check and keep twisting it to see if it will stay on the barrel.
Step 2: The Magazine
This step is very easy to do and only will take clear duct tape. This step will allow you to release the magazine of the gun without pulling back the orange magazine release. This will make the gun to release and reload magazines and ammunition faster more efficiently and more technically.
Step 3: End
This has been a tutorial with the Alpha trooper CS 12 nerf n-strike elite thank you for choosing this instructable. If you would please like comment and share. Employees motivate me by hitting the follow button. Thank you and have a great time with you modified alpha trooper CS 12.
    • Slow Cooker Challenge
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    3 Comments
    I would think that a nerf elite spectre "surpressor" might be better than the n-strike version...color on.
    What does the phrase "This barrel extension will hurt you anymore and make it a lot less work for you." mean? It doesn't make sense to me.
    Idea- Remove suppressor from spectre and use a longstrike barrel extension. Use PVC to create a silencer and paint it orange (so you dont get in trouble). Slide it on Longstrike barrel.
    Cool, however, barrel extensions actually decrease range because the dart bounces off the inside, transferring its energy to the barrel. However, the spectre barrel you have used is designed for whistler darts, and this means the barrel extension doesn't hinder the dart. So your barrel extension is purley a cosmetic mod. Cool anyways.
