Introduction: NERF Recon Light Minimization
Picture of NERF Recon Light Minimization
This is a simple mod to make the light from the NERF Recon fit the NERF Stampede.
Step 1: Cutcutcut
Picture of Cutcutcut
Cut along the red lines. You can use a Dremel cut off wheel, leaving a small amount of extra plastic. Then use some fine sandpaper mounted to a flat surface to get the edges flat and matching eachother.
Step 2: Fitting the Battery Tray
Picture of Fitting the Battery Tray
You will also need to cut out a slot for the switch.
Glue the pieces back together. I used Weld-on solvent, but super glue would work, or even using a soldering iron to weld it.
Carve out the shell to fit the battery tray as shown.
Step 3: Battery Cover
Picture of Battery Cover
The tactical rail clip will double as the battery cover. To do this, mark and drill a tiny hole on the skinny end slightly larger than the screw from the battery cover, then insert the screw. Be sure to put the tiny clear plastic washer back on it to, this helps to avoid losing the screw when you change batteries.
You will also need to file the overhang off on all but one of the sides of the clip, so it can come out easily.
Step 4: LED
Picture of LED
Mount the LED upside down, and cut the corners next to the wires.
Step 5: Cover
Picture of Cover
Cover up the back with some scrap plastic. I cut some polystyrene by hand an sanded & checked until it fit. Glue it to one side of the shell.
Step 6: Done!
Picture of Done!
Reassemble, load it with batteries, and prepare for "accurate" shooting!
MsSweetSatisfaction (author)2014-11-08
Nice nerf mod! I would love to see how well it shot in a demonstration.
About This Instructable
414views
5favorites
License:
Bio: Industrial designer, maker, overgrown boy
More by sweeezn:Better Makerbot Replicator 2 ButtonsLive Trace (Image Trace) for Laser CuttingNERF Recon Light Minimization
Add instructable to:
