NERF Retaliator Mod
Introduction: NERF Retaliator Mod
In this instructable, i will show my custom, easy, and efficient NERF Retaliator mod.
Step 1: Needed Items
To do this NERF mod, you will need several items:
1. NERF retaliator (duh)
2. Tape (you may need to cut)
3. Scissors (if needed)
Step 2: Cutting Tape
All though this step might feel 'kindergarden-ish' but it helps to know the measurements before you cut away...
You will probably want to cut you're tape at 1/2 an inch left to right, and 1 1/2 up up to down...
Step 3: Fitting
To fit the tape into the gun, you will want to put the tape about 1 1/2 MM behind the orange dart release clip and then fit the tape over the clip until it is leveled to the inside of the gun.
Step 4: You're Finished
Now fit your mag into the gun and now you no longer have to pull the orange button at the sides of the gun to take the clip out! You can now pull it out freely! Good luck!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    He's right about the clip falling out but any nerf retaliator mods make it better
    Cool concept, however it's really not that hard to pull the mag release in the first place, and the mag can now fall out, reducing rate of fire for ease of reload. Honestly, it's cool but not practical
    JackDC200, I'd like to thank you for submitting thus comment. I am aware 9th this, this is why I put down multiple layers of tape on the mag holder, therfore I would not be easier to fall out. that is a big help but it is easy to miss, I apologize for any inconvenience. Thank you for submitting your comments and I will be sure to check that out next time I will double check and make sure that I did not fail to make anything else as clear.
