3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Perfect NES Controller Wallet (no show)
My brother and I were talking a while back about things to make out of NES controllers, this inspired me to make a wallet out of the one i had sitting in my attic. After looking at the two instructables on here(the only other two on the web that I could find) I decided that I wanted to make my own, as I didn't like that both of them were really thick. So here is my NES controller wallet, no thicker longer or wider than a standard NES controller, and it fits up to two credit cards. I apologize in advance for the crappy pictures.
Step 1Tools
Tools
The tools that you should need are: your favorite rotary tool - mine is a GMC, but anything that can spin at variable speeds and use a grinding wheel, sanding drum, and small drill bits will work. Next is a razor blade, it really helps to remove excess pieces of plastic from the grinding/sanding Also along the lines of removing extra plastic is a small file, not really needed, but it helps to clean up rough edges. Needle nose pliers and wire cutters are very helpful, but not necessarily needed.
items not pictured (because I forgot):
A small phillips head screw driver. 2 post (not hanging or loopey) earrings with that you are willing to destroy. A small tube of super glue. A length of ribbon, about 3/4" wide and the length of the controller on the inside. And lastly some super tacky craft glue. Oh yeah, and a NES Controller.
5 comments
Jan 7, 2009. 2:28 PMzenilorac says:
i like the button retainer bit, the earing closure is kinda interesting too. the original was made as proof of concept using what i had to hand in a short time frame. -a last minute competition entry, i didnt imagine anyone would atempt to make or improve on this idea its good to see a different way of making this :)
Aug 13, 2008. 11:02 AMNeonLime says:
That is en amazing idea with the earings, I've never seen a better NES wallet, Well done.
Aug 11, 2008. 11:11 PMikoda says:
Where can you get a NES controller nowadays?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mistercow.pnoy
