3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
NES PAD LED's
NES PAD LED\
So I've noticed that there's "alot" of people, talking about how they would add LED's to their NES pads, that lights when a button is pressed. Sadly noone seems to do anything about it, but one guy who just added LED's that was on constantly...
So I desided to something about it :-P
Attached: Small video of me demonstarting that it works...
Step 1Disassembly
Disassembly
Unsrew the casing, and take out the curcuit board.
17 comments
Feb 2, 2010. 1:47 AMsamuraiclinton says:
LEDs to indicate momentary activation? Is that really necessary?
Aug 27, 2011. 7:09 AMOi23 says:
No,but in my opinion,it's pretty cool.
Aug 25, 2006. 1:25 PMmrbob1000 says:
to make it so you can press more buttons and it will still work is if you use a stronger resistor so less current is used by the leds (or you could use a diffrent color so that it would use less current)
Dec 7, 2007. 12:26 AMdenilsonsa says:
Maybe if all LEDs share a common resistor, then they won't be able to draw too much current? I'm not very sure about this, can someone please confirm this? Of course, this has a side-effect of LEDs becoming dimmer when more buttons are pressed at same time.
Sep 23, 2010. 10:04 AMblackcorvo says:
the problem with sharing one resistor to more than one LED is that not all LEDs are "perfect twins". they may not have the exact same intenal resistance.
that means they maybe would not light up with the same brightness if they shared the same resistor...
but you can try it, if you want. this kind of conficuration won't fry your LEDs or anything, and if you google a bit you'll find LED resistor calculators with single LED, parallel LEDs and even series LEDs options. you'll just need to put the source voltage, the voltage you want across the LED and the current going through it.
Nov 18, 2008. 9:40 PMHedgerow says:
you could mount a watch battery inside the controller for the leds. a decent battery should last quite a while and not be too impractical. there is plenty of room inside an nes controller to leave one in there.
Jun 30, 2008. 10:47 PMzmandudesk8 says:
motherboard, but same thing : ] this is way better than some other mods
Aug 23, 2006. 2:44 PMjoedog86 says:
The perfect project for an electronic hobbyist on a rainy day - I like it!
May 24, 2008. 12:40 PMNetReaper says:
no, i can take this project and take the entire day to finish
Sep 5, 2006. 10:24 AMtrsuco says:
What is the voltage on the resistor. It restricts 100 ohms and ??? volts.
May 17, 2008. 12:12 PMnevermind1534 says:
FIVE VOLTS. emember that it connects to the +5V connection on the board.
Sep 3, 2007. 1:19 PMNeodudeman says:
Nice
Oct 30, 2006. 7:27 PMzachninme says:
It's now gray...
Aug 22, 2006. 3:43 PMTheCheese9921 says:
yes finaly, someone got of there butt and did it
Aug 22, 2006. 3:42 PMThe3rror says:
Its so simple but I love it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Silas
