3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
NES PAD LED's
Step 3Fire up your soldering iron
1 - Solder a 100 ohm resistor, to the positive pin of the LED.
2 - Solder wires to the LED (pic 1)
3 - Add some hot shrink tubing, and shrink it.. (pic 2)
4 - Make as many as you need.
5 - Add the LED's to your pre-drilled holes, and bend down the pins. (pic 3)
6 - I've done a little "pin out" for for all the buttons. (pic 4)
7 - Solder the nedgative wire of the LED to wichever button you want. (pic 5)
8 - Now solder all the positive wires to the white wire (5V+) on the other side of the curcuit board, and bend them away, so you can close the NES PAD. (pic 6)
Notes:
Allthough the LED only will be lit for a short second, you need atleast an 100 ohm resistor. If you do not use a resistor the LED will draw too much current, and the NES PAD will not be able to send signals to the NES, thus your buttons will not work.
You can add LED's individually to all the buttons, but if you press more than 3 buttons at a time, they might use to much current, for the NES PAD to work properly..
2 comments
Sep 5, 2006. 10:24 AMtrsuco says:
What is the voltage on the resistor. It restricts 100 ohms and ??? volts.
May 17, 2008. 12:12 PMnevermind1534 says:
FIVE VOLTS. emember that it connects to the +5V connection on the board.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Silas
