NES ZAPPER!!!
Step 5Almost there
Almost there
Okay, this is the last step basically. Make sure the wires are long enough. The push button fits perfectly in the bottom hole so I just placed it there. Next the battery fits good where the counter balance was in the handle, you might need to twist off these little plastic nubs on the other half of the pistol. You'll know what I'm talking about when you're closing it all up. Attach the laser module with some tape or hot glue where the other counter balance went in the barrel. Then just run the negative wire to the battery and the positive to the trigger. I've included a picture with all the wires outside so its easy to follow them.
1 comment
Apr 8, 2009. 9:07 PMJacobAziza says:
If you left in the infra red LED instead of the laser, but did the battery mods, you would have a really cool gun to use in "lazer" tag, which usually actually use infrared LEDs, not real lasers.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:Darkeru
