loading
Quit pulling your hair out over incorrect passwords. Using an Arduino Leonardo and Adafruit's NFC shield, you can unlock your computer with an NFC card. The Arduino reads the NFC card's unique identifier and once it receives the correct one, it uses the Arduino Leonardo's keyboard emulation feature to type a password.
Step 1: Parts Needed
You will need the following parts for this build:
Arduino Leonardo
Adafruit's NFC Shield
NFC Tag (included with shield)
A Small Piece of Hookup Wire
You will optionally need:
More NFC Tags (available from Adafruit)
Tools Needed:
Sharp Knife
Soldering Iron
Wire Cutters and Strippers
Computer
Micro USB Cable
Step 2: Hardware
You will need to solder the header pins to the shield and retrace the jumper for this project to work.
Step One:
Solder the header pins to the shield. The easiest way is to insert the header pins into the Arduino and place the shield on top of the header pins. Solder the header pins on the top of the shield.
Step Two:
Cut the jumper between the IRQ pin and Pin 2 using a sharp knife. We need to do this because the NFC shield doesn't communicate with the Arduino Leonardo at Pin 2.  Use a multimeter to check continuity between the two pins.
Step Three:
Strip about 1/2" of insulation off of each end of a small piece of wire. Then solder this wire between IRQ and pin 6 on the Arduino.
Once all of that is done, the NFC shield is ready to communicate with the Arduino.
Step 3: Software
The software that needs to be uploaded to the Arduino is below. Make sure that you have the Adafruit NFC Library installed. Learn more about that here.
#include <Wire.h>
#include <Adafruit_NFCShield_I2C.h>
#define IRQ 6 // this trace must be cut and rewired!
#define RESET 8
Adafruit_NFCShield_I2C nfc(IRQ, RESET);
//////////////////////////////////// SETUP
void setup() {
  // set up Serial library at 9600 bps
  Serial.begin(9600);
  // find Adafruit RFID/NFC shield
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
Keyboard.begin(); //initiate the Keyboard
/////////////////////////////////// LOOP
unsigned digit = 0;
void loop() {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 }; // Buffer to store the returned UID
  uint8_t uidLength; // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // wait for RFID card to show up!
  Serial.println("Waiting for an ISO14443A Card ...");
  // Wait for an ISO14443A type cards (Mifare, etc.). When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  uint32_t cardidentifier = 0;
  if (success) {
    // Found a card!
    Serial.print("Card detected #");
    // turn the four byte UID of a mifare classic into a single variable #
    cardidentifier = uid[3];
    cardidentifier <<= 8; cardidentifier |= uid[2];
    cardidentifier <<= 8; cardidentifier |= uid[1];
    cardidentifier <<= 8; cardidentifier |= uid[0];
    Serial.println(cardidentifier);
    if (cardidentifier == 606061173) {
      Keyboard.write('m');
      Keyboard.write('y');
       Keyboard.write('p');
        Keyboard.write('a');
         Keyboard.write('s');
           Keyboard.write('w');
            Keyboard.write('o');
             Keyboard.write('r');
              Keyboard.write('d');
              delay(5000); //makes sure the password isn't repeated
Once the code is uploaded, open the serial monitor set at 9600 baud. Place the NFC tag on the shield for a second and then remove it. The serial monitor should say, "Card detected #card number." Copy the unique card number and paste it in the cardidentifier == 606061173 statement in the code. The card number will replace 606061173. Then change the keyboard.write statements to spell out your password one letter at a time. Reupload the code and whenever the NFC tag is placed on the shield it will type your password for you.
Step 4: 3D Printing
You can optionally 3D print an enclosure to house the Arduino and to mount it onto a desk. The .stl file is on this page. The two screw holes on the case allow a long screw to pass through. This is meant to be mounted underneath a desk. The NFC signal should work as long as the table is thinner than 5cm.
<p>I added some simple AES encryption using Davy Landman's AESLib for Arduino; please see my repo here: https://github.com/nhenderson/Arduino-NFC-Computer-Unlocker.</p>
<p>I just got to your code and have some questions. Could you give me your email please?</p>
That's awesome! I'll check it out soon!
<p>why do you have to change the pin from 2 to 6 ? </p>
<p>The NFC shield doesn't talk well with the Arduino Leonardo at pin 2. Pin 6 is the IRQ pin that works on the Leonardo. </p>
<p>i see, but maybe you should tell that in the instructeable ? :) so people with an uno dont do it, and in the code explain what it should be for uno and leonardo ? :) </p>
Doing this using an arduino UNO is an entirely different matter. The Leonardo is able to act as a HID because of its special AVR chip which combines the actual microprocessor and the processor used for serial communication on an UNO or an Mega (or an 2009, if I am not mistaken). If you have an UNO or Mega available, you can see this second microcontroller for USB communication next to the USB poet. It will have something like Mega8U2 or Mega16U2 written on it. Using such Arduinos as a HID is pony possible by flashing a different firmware onto this chip using something called DFU. This involves cutting a jumper on an UNO R1 and will make your arduino inaccessible for programming until you flash the vanilla firmware onto the chip. Speaking from experience, this is kind of annoying.
*only
This looks like a nice idea. And it is a great example of the keyboard function of the Leonardo. <br><br>My one concern is that you are storing the password in clear text in the arduino code. If some stole the arduino they'd have your password. <br><br>Have you thought about using the NFC reader as part of a two-factor authentication system? So you would need both the card and a password?
<p>As far as I know you can't read the code off an Arduino. Also if you 3D print the case it will be bolted to your table :-)</p>
<p>I think that he meant to say:Someone might steal the arduino,and trigger the kev presses,then in something like notepad,they'll see the password being typed out for them.</p>
<p>so the code says uploading then just sits there and never finishes-anyone have that problem?</p>
<p>I'm having some problems I hope you can help me with on this project. </p><p>I'm getting this error message. </p><p>Keyboard_NFC_Unlocker:61: error: 'Keyboard' not found. Does your sketch include the line '#include &lt;Keyboard.h&gt;'?</p><p> Keyboard.write('m'); //update with your password!</p><p> ^</p><p>exit status 1</p><p>'Keyboard' not found. Does your sketch include the line '#include &lt;Keyboard.h&gt;'?</p><p>Adding #include &lt;keyboard.h&gt; just tells me the file can't be found. Any help would be awesome. Thanks!</p>
<p>Did you ever get answer or figure this out?</p>
<p>I have same keyboard error as <a href="/member/npro6979" rel="nofollow">npro6979</a></p><p>Can you provide any guidance on how to fix this please?</p>
<p>This might be a dumb question, but I don't see how the arduino is connected to the computer after it is programmed? Does the USB have to remain constantly plugged in to work? Or is it programmed to send the password over wifi?</p>
<p>Hi, will this work with a phone as an NFC tag?</p>
I don't think so.
<p>The reason I asked was, like any nfc card or sticker.... there is an identifier to verify it. Just like the card or sticker, doesn't the phone also have a unique number that we use for payment or file transfer? So in theory the technology should be able to work with few tweaks right? Just was an idea </p>
<p>Yes, it should on the condition that the NFC shield mentioned here supports the NFC tech that the phone would emulate. Check this out: http://developer.android.com/reference/android/nfc/tech/package-summary.html</p>
<p>Hello, I'm really interested on this little project. But I have one question. I was wondering if this will also work on windows 8, or if the code you provide is only for Macs. Thank you.</p>
<p>Yes it works great! That's where I mainly used it. </p>
<p>Ha, OK. Thanks a lot! :)</p>
<p>can i do this using a arduino mega and elecfreaks NFC shield? <br>thanks in advance</p>
I think a mega should work you would just have to switch the pins around. I don't know about that shield. The code is for the Adafruit one.
<p>Hi, thanks for this great idea. HOWEVER, this does NOT UNLOCK your computer, it enters your password. The title is misleading. Please update your title to something like &quot;NFC Computer Password Autotyper&quot;.</p>
<p>you could add this piece of code so that you don't have to even press the enter key </p><p>Keyboard.write(KEY_RETURN);</p>
<p>Very nice little project that also means you can have ludicrously long passwords to keep unwanted siblings out of your system.</p>
<p>Really cool stuff! But a couple recommendations.<br><br>I would recommend using an auxillary program (perhaps a web service) to store and manage what passwords map to which cards. Just have a simple interface where your device contacts a web service running on your network somewhere, if the card is a new card, it will register it in the database along with a timestamp so you can go in and assign a username and password to it. The password would be encrypted of course. Then find a way to either have the web app authenticate you and let you in, or come up with another way to input the password.<br><br>It's just that hard coding anything into a program..especially something sensitive like a password, is just a bad idea. And from a design perspective, a violation of DRY among other things.<br><br>All that being said though...this is a clever idea, and I would love to see you develop it further. If I can be of any assistance, let me know. I can help you write the web service.</p>
<p>Thanks for the idea! You are right, this project is probably not too secure. I posted this as more as a concept. For a business computer, this probably isn't the best idea! :-)</p>
I have been meaning to do an instructable about the smart power strip I have been working on using Arduino and a Web Application that controls it. The prototype is done, just been too lazy to finish.
Also, I would strongly recommend looking at the algorithms for authentication and encryption built into some NFC tags for added security.
<p>Hey, i had a question. I have a Nexus 5 with built in NFC, do you know if it's possible to use that NFC chip? If so, how?</p><p>Thanks in advance and thanks for this guide :)</p>
<p>I don't believe it is possible to use a phone to interact with the NFC Shield. The shield and your phone are only meant to read and write to cards, not to be one itself. You could take apart the card and put the small NFC circuit in your phone case;-)</p>
thats strange, the nfc on my nexus 7 communicates with other devices via nfc. its used to share things, such as apps and webpages.
I am afraid this will probably not work since your phone has got an NFC chip which transmits in an &quot;active mode&quot;, as opposed to the passive Mifare cards used in this project. I can assure you that your phone could not interface with this board using the code in the instructable, as that would require the NFC chip in your Nexus to be able to emulate the technology in the Mifare card, which requires special hardware and can't be done in software. It might be possible to program the arduino to interface with an active target and write an Android app for interfacing the board. This will, however, be quite hard to do.
You might be interested in this video from Google IO 2011 (it's annual developer conference), which is quite long and technical, but very helpful, to get a comprehensive overview of this rather complex matter: Google I/O 2011: How to NFC: http://youtu.be/49L7z3rxz4Q
<p>Nice Job.</p><p>It would be nead to have a separate authentication process instead of emulating a password.</p><p>See here </p><p>http://en.wikipedia.org/wiki/Graphical_identification_and_authentication</p>
<p>So does the keyboard emulator allow for special chars typed simultaneously? Could you extend this to unlock the computer with ctrl+alt+del enter, then the password?</p>
<p>There's no &quot;ascii&quot; character for Ctrl, Alt, Delete but you can do something like</p><p>Keyboard.press(KEY_LEFT_CTRL);<br> Keyboard.press(KEY_LEFT_ALT);<br> Keyboard.press(KEY_DELETE);<br>delay(100);<br> Keyboard.releaseAll();</p><p>//Write password here</p><p>Keyboard.write(KEY_RETURN);</p><p>That would work :)</p>
<p>You could totally do that! Just have the keyboard.write statements press ascii number for the key you want to press. View all of the Ascii numbers here: http://www.asciitable.com/</p>
<p>Could i use my mobile to unlock it?</p><p>Or is that like holding a reader to a reader?</p><p>Would be kind of cool to unlock the computer just by placeing your android on the table.</p>
<p>I haven't had any luck getting my phone to work, I think its like holding a reader to a reader. </p>
<p>Looking at google, I'm assuming there is nothing to stop you writing:</p><p>Keyboard.write(KEY_RETURN);</p><p>after your password to cut out pressing enter? Make it more automated like!</p>
<p>That's a great suggestion! Sometimes I don't need the enter key to be pressed when entering a password. For that reason I didn't do that. </p>
going to assume you use it for more than just your login? - e.g. website logins or signup pages which require pass but not ENTER as it would submit form too quickly?<br><br>I guess theres nothing to stop you using a second NFC key through so you can have 1 with enter and 1 without!<br><br>I do love this idea through, imght favourite it so I can give it a whirl when I have some spare time!<br><br>Out of interest how did you manage to make your box? 3D printers are extremely expensive and I can't imagine you went to that length?
<p>Let me know if you do make it! I did use my Printrbot to print a case for the project. You could either use an online print service or take it to a local hacker space (if you live in a big city). </p>
<p>Just a random thought but how does this cope when first switching on your computer? Does the NFC service start before you've even logged in initially - or does it only work once you've logged in and you &quot;lock&quot; your computer?</p>
<p>This works all the time after the Arduino starts up (about 5 seconds.)</p>
About This Instructable
85,701views
592favorites
License:
More by The Electrodog Show:Checking Battery Status on Mediatek LinkIt One Checking Your Current Location With MediaTek LinkIT One Controling Low Voltage Devices with MediaTek LinkIt One
Add instructable to:
