NFC With Raspberry Pi and Arduberry
Published
Introduction: NFC With Raspberry Pi and Arduberry
The Arduberry is a simple and inexpensive way to bring Arduino shields to the Raspberry Pi. The device is a shield that slides over the Raspberry Pi and allows you to stack and use Arduino shields. The Arduberry requires no physical configuration to work with most shields. You can write Arduino sketches (programs) right on your Raspberry Pi.
This example will show how to use a Adafruit NFC shield to read an NFC card using the Arduberry.
Step 1: Hardware Required
  1. Raspberry Pi
  2. Arduberry
  3. Adafruit NFC Shield
  4. NFC Cards
Step 2:
Slide on the Adafruit NFC shield on the Arduberry and power on the Raspberry Pi.
Step 3:
Download the Adafruit NFC shield I2C library on the Raspberry Pi using the Netsurf Browser and save it in /usr/share/Arduino/libraries and extract it there.
Step 4:
Open Arduino, and open the example readMifare from the Adafruit_NFCShield_I2C folder. Change the programmer to Raspberry Pi GPIO and upload the sketch to the Arduberry(use Ctrl+Alt+U).
Step 5:
The data that is coming from the NFC shield is coming at 115200 baud, so we need to configure minicom. Open a terminal and open minicom setup.
minicom -s
Step 6:
Go to Serial Port Setup Menu and press Enter
Step 7:
Press A to select the device and change it to /dev/ttyAMA0 and press enter to save it. Also press F to disable Hardware Flow Control. Press Enter to save the settings.
Step 8:
Select Exit to open minicom.
Step 9:
Now place the NFC card over the Shield to see the data stored in the NFC card.
Have a question? Post it on the forums and we’ll help you out.
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    I have a question. Can a NFC mobile device become or act as a NFC card?
