NO Battery NO Problem
Published
Introduction: NO Battery NO Problem
About: Life Hacks, How to, DIY, Tips, Tricks and much more... Follow Me: http://www.youtube.com/videoblinks https://www.facebook.com/videoblinks https://www.pinterest.com/videoblinks/
Simple Hack if you ever find yourself missing one battery.
Items Required: Aluminum Foil
This hack works on many items requiring batteries.
Step 1:
In this example I will demonstrate what to do if you have one battery and your flashlight requires at least two batteries.
Step 2:
To replace the 2nd battery you can use aluminum foil rolled up to similar size of actual battery.
Step 3:
Next step is to place the aluminum foil in the flashlight followed by regular battery.
Step 4:
If you did steps above correctly you should be able to use your flashlight with only one battery when 2 batteries are required.
    • Creative Misuse Contest
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    6 Discussions
    okay thanks! do you know if this will work with a nerf gun?
    It will run at half the voltage, expect it to be atleast half as bright, of not even less bright.
