Step 5Applying cement (darker areas) along diameter and dart edges
If the cut edges of the leather are a different color than the show side, use a permanent marker in a similar color to dye the cut edges. The seams will be less visible, and the circumference look more finished, if similar in shade to the background color of the show side. (The demonstration kippah has a white background and white cut edges.)
Apply a 1/4" band of cement, brushing from the center of each large piece towards the diameter and dart edges only - not along the circumference.
Extra glue will help the kippah stay in place when worn, but it looks sloppy. Follow manufacturer's directions for contact cement; use wet, allow to become tacky, or set until dry, before assembly.
Add Comment
