NOT GATE Using Transistor
Published
Introduction: NOT GATE Using Transistor
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
This is very informative intructable post
Most of us don't know the secret behind the simple NOT GATE
NOT GATE is nothing but a single transistor
You can make easily in 2 minutes also you can verify the out put .....
Check out the complete video tutorial.....
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    5 Comments
    While this circuit does invert the signal in your simulation, it is not actually a NOT gate. A correct NOT gate would be actively driven. For a 5V TTL circuit: if the input is at least 2V, the output is pulled high (5V); but if the input goes below 0.8V, the output is pulled low (0V).
    http://www.allaboutcircuits.com/textbook/digital/c...
    https://en.wikipedia.org/wiki/Inverter_(logic_gate...
    yes you right
    low level is considered here 0.7 - 0.8 volt
    Not exactly. For TTL, you are right. However, for DTL, you are incorrect--passive pull up is used.
    "This is very informative intructable post" ....
    Well... I think NOT. Just a video without any ohters materials( schema/parts/tools/values) if you want to win videos view this isn't your site. Please, post images with more info and some text. THIS is the idea of Instructbles, not a site to win YT views
    OK bro
    In all my upcoming instructables I will share each and every things required to make a featured and good instructables
    thanks for your advice
