Nail Polish Marbled Flower Pots
33,055
322
15
Published
Introduction: Nail Polish Marbled Flower Pots
These nail polish marbled flower pots would make a unique and colorful addition to your backyard, garden, or home!
Since nail polish dries quickly, you'll get satisfyingly fast one-of-a-kind results.
You can also use this technique to marble pretty much anything, and you'll definitely want to!
Looking for more flower pot design ideas? Check out my Instructable for instructions on how to make a Drip Paint Flower Pot.
Step 1: Gather Your Supplies
You will need:
  • a flower pot
  • nail polish
  • disposable container that will fit your pot
  • toothpicks
  • gloves
  • paper towels
  • nail polish remover (acetone)
  • lukewarm/room-temperature water
Step 2: Paint Your Pot
I painted my pots with a white enamel spray paint so that the nail polish colors would pop. If you are using pastel-colored nail polish, you could probably leave your pot terracotta colored.
You can invert your pot over a tin can to keep it off of the ground while painting.
Step 3: Marble Your Nail Polish
Test your container to make sure your pot fits. The container doesn't have to be too deep because the nail polish should stay at the surface of the water, but it should be able to fit the length and width of your pot. The bigger the surface area, the better. A bigger surface area means more area for your marble design.
Nail polish marbling can be a bit tricky, so I would suggest that you practice a bit before trying it out on your pot. (To be honest, it took me more than a few tries to get the technique down.) Once you are comfortable with the technique, you will want to marble EVERYTHING!
Start by filling your container with lukewarm water. I tried hotter water, but I found water that was slightly warmer than room-temperature worked the best for me.
Put some gloves on when you start to work with the nail polish because removing nail polish from your hands can be a chore.
Pour your nail polish from the bottle to the water. Try to pour slowly and close to the surface of the water so that your nail polish doesn't sink to the bottom of the container in globs. The first color that you start with should be your lightest because it will spread out. If you are finding that the polish dries to quickly, or doesn't spread out, try adding a little bit of nail polish remover or acetone to the water.
Next, pour in your second color. Use a toothpick to swirl the colors and get a marble happening.
Limit the number of colors you use to 1-3.
*Since nail polish dries fairly quickly, you will need to work fast*
Step 4: Transfer Marble Design to Your Pot
Start at one end of your container and touch the side of your pot to the surface of the water. Rotate your pot so that the nail polish wraps around it. Place your pot on some paper towel to dry.
If your container wasn't big enough to have your marble design go all the away around your pot, you can repeat the process and marble some more. You can also marble over your dried marble design if you want to add more color. Change the water every time you make a new design.
Step 5: Seal Your Pot
Add a few coats of clear enamel paint to protect your design. Also seal the inside of your pot if you are using terracotta pots because terracotta likes to absorb water and the water might push off the paint.
Step 6: Done!
Backyard Contest
Runner Up in the
Backyard Contest
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    15 Discussions
    DO U THINK IT WOULD WORK ON PLASIC TUBS LIKE THE 1S U GET READY MADE PASTA SALADS OR GREEN SALADS IN SEE SOME HAVE LIDS IM THINKING IT BE GREAT FOR PARTYS TO PUT STUFF LIKE CRISPS IN AND WITH THE LID U COULD PUT THEM IN THE TUBS BEFORE U GET READY LOL AND IVE HEARD SOME SAY U CAN USE PAINT TOO
    These are lovely - thank you so much for taking the time to share them. I love them.
    I lobe these that really cute ??xx
    Nabiel
    3 years ago
    SWEET going to try red yellow n green together. Irie mon!
    cool! i ll try it on something like maybe a cofee mug, or a lamp or Anything!
    These look great. .thankyou for the info. I will be trying these soon.
    these look great. especially like when the colors on the pot match the flowers in it
    Great art! The final designs look absolutely amazing.
    However, I have a doubt. Can I use this technique to paint pots made out of clay?
