Step 5The tricky legs....
First decide how tall you want your bed to be (in my case 23") and cut the pole, but take into consideration, the thickness of your mattress, the 6" of the board that will slide into the pole. AND ONCE AGAIN 90ý cuts must be very well done!
You must cut a cross shape into the pole at 90ý angles, the cuts must be as deep as the boards (6") so that they will slide all the way in, also the cuts must be a little bit smaller than the width of the boards to ensure a tight fit and no movement, you should be able to put them together tapping sligthly with a hammer.
Once more, just look at the pictures.... they are worth a thousand words.
comments
Add Comment
Tazo (author)
says:
Tazo (author)
says:
Add Comment
