Nanars 4 Lens Camera Winston Dismantle
64
Posted in TechnologyPhotography
Introduction: Nanars 4 Lens Camera Winston Dismantle
i ve found a Winston Nanars 4 lens action camera at the beach
it was dirty full of sand when i digged it out so
i wondered about what the hell that thing can be uses for
Step 1: Starting Dismantle
get a cross screwdriver type 00
and pieces of empty paper or cardboard and a pointed pencil or whatever you prefer to record the dismantling steps!
open the film - door
open all 3 micro screws hidden inside the back of the 135 film box
Step 2: Front Case
slide the silver front case part out to have access to the lens,
then remove the film door
Step 3: Enhanced Dismantle
go on like this with the rest of parts
open all the visible micro screws (total of 21 pieces 2,5 mm long)
Attention ! there s only one screw hidden under the top of the lens, remove the plastic film covrage
Step 4: Shutter
when it is done you ll be able to lift off the lens body, and see (find) the rotating shutter at the back of the lens
it is working like a simple clockwork just whith one turn spread
Step 5: Reassemble
after cleaning all the parts with some vinil cockpit spray
you can remount all bits toghether
in the reverse order
(TIP_: recommended that you have done a handwritten record where you found which screw where was removed, it makes it much easier:)
but in my case, the plastic lenses were blind from the years in the sand, so i ve thrown all to the garbage bin
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
