Step 6Plug it In and Finalize
As you improvise you might discover a lot of strange things: touching sensors together might cause weird sounds; depending on how you've wired it, touching the sensors without applying force might even cause some strange sounds.
If nothing works, check for broken connections or things in contact that aren't supposed to be in contact. Debugging these is probably more work than it's worth, and if it's not obvious you might be better off building a new one.
If everything works correctly, leave things plugged in and start hot gluing everything in place. Start with the audio connector, and then soldering "real" (shorter) connections between the chip and audio jack. Then hot glue everything that looks like it could ever come undone. This synth isn't meant to last for a long time, but the glue will help when you inevitably drop it. I leave things plugged in just to make sure I'm not breaking anything as I apply the glue.
Add Comment
