Nathaniel,Tiana,tanaejia Pallet Project
1,314
4
Published
Introduction: Nathaniel,Tiana,tanaejia Pallet Project
Me and my team worked veryhard on this project and hope you have fun making this project too.
Step 1: Pallet
check your pallet to see if there is a are and cracks
Step 2: Pulling Pallet Apart
Began to pull your pallet a part slowly so that you don't crack or damage your pallet.
Step 3: Sanding
Start to sand your wood so that splinters can be prevented
Step 4: Cutting
use a table saw to cute the wood it's much easer than a hand saw so that if you have to cut angles you can.
Make sure you measure each piece of wood so that at when you make flooring it's even.
Step 5: Floor
Measure the six pieces of wood so that it's even, make sure the card board is even with the pieces of wood lay some wood glue on the card board and place the wood on the card board.
Step 6: Gluing
take four pairs of wood that are even in measure ment and wood glue to of each pair to gether one on top of the other.
Step 7: Box
Then start to screw all four sides to the pieces of wood that's glued to the card board.
Make sure the pieces of wood on the card board attached and not lose from gluing if so wait the next to do so.
something like the image on the side
Step 8: Floor Part 2
measure a cut a piece of plywood so that it cuold fit in the middle of the box you just made.
Step 9: Chair
use five of your left over pieces of wood to shape and build the chair
Step 10: Attaching Chair
Attach that chair to the box
Step 11: Making Chair Stable
uses small little block of wood to suport the back of the chair
Step 12: Angle Cut
cut a small enouch piece of that wiith match up with the sides as well as the center bof the chair to the box. Make a 90 degree cut on the edge of the small piece of wood you just cut.
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    2 Discussions
    Nice! You may want to consider a more descriptive title so it's clear what you are making. And why is the bench attached to the box?
    Thanks for sharing :)
