Introduction: Natural Activated Charcoal (whiten Teeth)
Rice Husk ash has been in use since the beginning of Indus valley civilization in India. It's one of the best and natural alternative to substitute for chemical toothpaste. It can also do wonders such as teeth curing, cure alcohol-induced hangovers, and prevent bloating. Rice husk is a waste product obtained from rice plants.
Required Items:
Rise Hush
Earthern pots
Matchstick
Grinder
Gas stove
Iodised salt
Pepper
Step 1: Get Good Quality Rice Husk
Get hands-on good quality rice husk. They come mostly in golden color (It may vary with the plant varieties). Make sure there is no rice hidden in the husk, just husk in its raw form. Then scorch the husk under the sun for about 5 hours to eliminate any moisture content in it.
Step 2: Fry the Husk in Earthen Pot
Under medium flame scorch the husk for about 15 to 20 minutes till it changes its color to slight black. Once the husk is super hot, make fire with a matchstick and burn the husk (husk will catch fire - you just have to start the fire ). Keep the flame on till all of the rice husk is turned to ashes.
Step 3: Grind It Down and Filter Our Heavy Particles
Once the Husk ash is ready, take it out and gride it into ash powder. I mean it - if there is any ash particle in the powder then it will seriously hurt your tooth so be cautious. Further, remove any existing ash particle using winnowing.
Step 4: Flavouring Your Toothpaste
Mix iodized salt (powder) with pepper powder in 1:2 ratio which will give you a flavoring touch and also it has many medicinal properties in Ayurveda for gums and tooths. Clove, Barleria prinoitis bark, Cinnamon (in powdered form) can also be added to it. Now add husk ash to the flavoring powder in 20:1 ratio. Mix it well and keep it in a tight moistureless container and use it before 6 months from the date of production.
