Introduction: Natural Wood Clothes Pin Photo Holder
Picture of Natural Wood Clothes Pin Photo Holder
Here's a quick and simple project!  I'll explain how to make a simple and cheap clothes pin photo holder.
I had a bunch of spare materials from other projects, so it cost nothing and took 10 minutes to make!
**Made at the Techshop!**
Materials:
~3' section of a 2" by 4" (You can choose any width you please)
4 drywall screws
17 gauge wire
Small Clothes Pins
2 eyelets from an old picture frame
Equipment:
Drill with Phillips head drill bit
Wire cutter
Step 1: Hooking Up the Wire
Picture of Hooking Up the Wire
Drill a screw into the left and right side of the wood.  Maybe an inch or so from the edges. (Eye it to make them symmetrical)
From there, you're going to want to connect the wire to the screws.
I just spun the wire around each screw, and then drilled the screw a little deeper to tighten the hold.
Once connected, I just cut the wire from the spool.
Step 2: Dressing It Up
Picture of Dressing It Up
Add clothes pins, and photo's.  Determine how many photos and pins you prefer.
I think portrait oriented photo's work a little better.
Step 3: Mounting It
Picture of Mounting It
Now that you're all set up with design, we just need to set up the mounting hardware.
To get the hardware, I just disassembled an old picture frame and took 2 eyelets from the back to use for mounting onto a wall. If you are using a thicker piece of wood like this 2' by 4', you can also rest it on a window sill, a shelf, or a fireplace mantle.
I just drilled them into the back and it's now ready to mount!
I like the rustic look and how you can change out the pictures!
About This Instructable
456views
5favorites
License:
More by dirtrydr88:Beware of Dog SignShot Glass Tray DisplayOutdoor Bar Table Top
Add instructable to:
