3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Natural Wood Indoor Bicycle Stand for Under $15 USD
Step 2Preparing the wood.
Preparing the wood.
Cut wood to the following lengths.
4 - 12"
2 - 8"
2 - 4"
4 - 10.25"
2 - 10.75"
It is important that all cuts are as close to square as possible. The strength of the glue joints will depend on surfaces being flush and smooth where they are glued.
Note that the only dimensions that are specific to the Giant XtC are the 10.25" riser that the suspension rests on and the width of the bike frame at the support point. The other lengths are not critical. In fact, nearly all my wood pieces are shorter than the dimensions listed here. I have listed the dimensions without regard to saw blade kerf - the width of the cut the saw makes through the wood. Cutting a 12" length of wood stock into 4" and 8" pieces results in two pieces that are slightly shorter than 4 and 8 inches. The important dimensions are the height of the bike frame support riser (here 10.25"), the width of the 12" risers that the bike frame sits between, and the length of the base frame end pieces (here 10.75"). The latter dimension is governed by the width of the bike frame where you choose to support it; in my case, the width of the frame at the support point is 6.75", including approximately 0.125" (1/8") of extra clearance to make it easier to slide the bike in and out of the stand.
Sand all cut edges to remove ragged edges and to smooth the cut surfaces prior to gluing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Protostar
