Step 2Digging holes and placing posts
Based on the design that you choose for yourself, dig deep holes at least the height of your garden. You will also need to choose decently thick branches for the posts. I used the biggest I had, which was about 100-150mm diameter. These posts should be reasonably straight with minimal notches and the length should be at least twice the height of the height of the garden (plus some) - 1/2 will be under ground, 1/2 above ground and a little left over to trim flush with the timber beams.
Once the holes are dug, place the post vertical into the hole (you may want to use a level, however this may not matter too much as all natural materials are not perfectly straight). Following this, fill about 3 spades of soil into the hole around the post and then hammer the soil with a piece of flat ended timber. This will make the post sit firm in the ground. If the soil is wet this may be a problem, so perhaps wait until drier weather.
Continue until the level of the hammered soil is about 200mm from the surrounding ground level.
Add Comment
