3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Call of Duty 5 Nazi Zombies
In this Instructable, I will be showing you the best tactic on how to survive the mode: Nazi Zombies in Call of Duty 5, World at War.
Step 1Starting Off
Starting Off
Play with other people if you can!!!!!!!!!!!!
You start off with a very lame pistol. You should start searching through all the windows, and shooting any zombies that come near. When you have enough points, go ahead and buy a M1 carbine. Finish up the rest of your pistol ammo, and start using the carbine. NEVER EVER EVER EVER EVER EVER remove the sofa on the stairs!!!!!!!!!!!!!!!! EVER! If you do, it will be your end! Stay in that room until you run out of ammo or when the room is too crowded. When you run out of ammo, you need to open the door that says HELP. Open it and if you look on your left, you will find a chest, where you can get a random gun for 950 points. Don't get: M1 Garand, any snipers, or don't get the panzer(yet) . Get the flamethrower, ray guns, and machine guns, and pretty much everything else.
76 comments
1-40 of 76next »
Mar 10, 2012. 4:49 AMNATHYxPROxKILLS says:
I STAY IN THE FIRST ROOM WITH JUST A PITOL AND THE CARBINE UNTIL ROUND 5 THEN I OPEN THE DOOR (HELP)AND STAY IN THEM 2 ROOMS UNTIL ROUND 10 OR 11 THEN OPEN THE STAIRS IN THE SECOND ROOM AND CAMP THERE TILL I DIE BEST TO CANP WITH A RAY GUN AND A MACHINE GUN OR A ONE SHOT ONE KILL GUN.LOL IT IS EASY SURVIVED UP TO 87 ROUNDS BEFORE IT WAS EASY WITH 3 TO 4 PLAYERS.
Nov 26, 2011. 3:40 PMckuczer says:
http://www.GetMyMicrosoftPoints.com/?i=235065
Nov 26, 2011. 3:38 PMckuczer says:
Oct 23, 2011. 3:34 AMccallaghan1 says:
http://www.GetMyMicrosoftPoints.com/?i=224474
Oct 2, 2011. 10:35 PMdrowland3 says:
i bought world at war for my ps2 but all i can do is campain do i have to unlock zombies
Aug 3, 2011. 7:21 PMaleceatsfood says:
I REALLY need help! I bought waw for pc but I cant get any zombies maps. I cant find out how to download custom maps!!! help!
Aug 6, 2011. 8:55 AMaleceatsfood says:
ok well from callofduty.com/updates ? yeah I never have. Do I have to do every one or can I just do the latest patch?
May 2, 2011. 11:18 AMInstant RA-Man 696 says:
Who plays Black Ops on Xbox LIve?
Apr 16, 2011. 11:35 PMCapt. Kidd says:
Usually, i just stay in the starting room until i get swarmed, then go into the HELP room skipping the random box. I then open the stairs and buy a BAR. When i do, i go to the room in the upstairs with the sawed off double barrel and buy that. i hold off there, and when i get swarmed i switch to the double barrel and run around the pillar that's to the left. I turn around and blast both rounds then run away again as i reload. Lather, Rinse, Repeat. I got to round 40+ without the random box.
Mar 29, 2011. 3:01 PMneo-sky says:
actually u should open all doors by lvl 20 then go to where the grenades r and have 2 guys killing zombies coming strait at u and the other 2 covering the stairs and the window
Nov 23, 2010. 1:15 AMLifeGuard says:
Hi guys kinda new to this website but i know a great glitch that works nearly all the time but might take some practise. First on Nachd der Untoten hold out the starting room for the first 5 - 7 rounds (best to use multiplayer) next open up the help door, then if you have the points get a really good machine gun browning etc. Finally open the stair case inside the help room only and then head upstairs to the room with the grenades on the wall. Now for the slightly tricky bit, what you have to do is:
FOLLOW THESE INSTRUCTIONS CAREFULLY OR YOU WILL LOSE THE GAME!
1. line your cross hairs at the grenades on the wall.
2.sprint towards the grenades.
3. Whilst sprinting jump and hold down the crouch button until you have landed facing the wall in the prone position (LAYING DOWN).
4. turn around using the RIGHT!! analog stick only and once facing the door way press the crouch button once, to be in the crouch position then press it one more time and a message on your screen should appear saying can't stand here. this means that you should be in position. WHAT EVER YOU DO DONT TOUCH THE LEFT ANALOG STICK OR YOU RISK LOSING THE GLITCH.
5. Once this happens test the glitch by lettting a fwe zombies come up to you and if they stop walking and start swinging there arms without moving forward then your in business i.e. start killing without worrying about them killing you.
6. if you run out of ammo dont worry just look around using the right analog stick and purchase the grenades remember DO NOT TOUCH THE LEFT STICK
Now hope you guys and gals out there enjoy this and if you are wondering yes it works on both xbox and ps3 platforms now go have some serious fun
Dec 27, 2010. 12:35 AMbeehard44 says:
HAX!
May 13, 2010. 12:16 PMKNEXFRANTIC says:
shawed off doble barel is beter than the trench gun because you get beter spay
Aug 27, 2010. 8:56 PMdivinehex says:
lol, yeah, I have started getting multiple shotguns eg: trench gun+sawnoff because they use the same amount of ammo and then I can get ammo from any of the 2 shotgun outlines if I am in trouble, also the sawnoff is good with the trench gun because then you can just fire at them with your trench gun then switch to sawnoff, that way you can rescue your friends and most of the time you can kill about 14 zombies with 2 fully loaded shotguns :)
Aug 28, 2010. 2:41 PMKNEXFRANTIC says:
their awsome arent they
Aug 28, 2010. 9:42 PMdivinehex says:
hell yeah!
Aug 29, 2010. 4:52 AMKNEXFRANTIC says:
i know
Aug 22, 2010. 3:34 AMdivinehex says:
usin a swanoff is suicide, you very rarley have that sort of firepower on your friends, but it is an exxellent backup weapon for if your first one needss to reload and you are being rushed by the zombies.
Aug 24, 2010. 10:57 AMKNEXFRANTIC says:
i only buy it when some one has a hmg or lmg or smg or wunderwaffe
Aug 15, 2010. 7:45 AMonemanarmy675 says:
NEVER DO THAT! ITS RELOAD WILL KILL YOU AND YOUR FRIE DS IN THE LATER ROUNDS!
Aug 17, 2010. 6:23 AMKNEXFRANTIC says:
not if your freinds have belt fed machine guns and wuderwaffes
Aug 8, 2010. 6:46 PMfeed288 says:
you start of with a pistil use it until it runs out of ammo then if you get enough points open the help door or the stairs get a shotgun or a machine gun or whatever weapon you prefer then hold out in the room with the random gun box trust me it works please comment
Dec 26, 2008. 5:28 PMlil jon168 says:
can u play this online?
Jul 10, 2010. 1:01 PMharley barnes says:
ya why
Dec 30, 2008. 12:50 PMlil jon168 says:
lol right when i asked i found out
Jul 10, 2010. 1:00 PMharley barnes says:
it ment help me to beat it
Apr 23, 2009. 9:53 PMBuzzsushi says:
always get m1 garand with launcher and panzer. if you blow up the box while it is picking the game it will give you a ray gun every time. And the PTRS is insane against zombies
May 13, 2010. 12:13 PMKNEXFRANTIC says:
i agree also will that glitch work on the ps3
May 13, 2010. 3:55 PMBuzzsushi says:
They probably patched it by now, I haven't played zombies in a while. So I wouldnt know
May 14, 2010. 10:56 AMKNEXFRANTIC says:
damn it lol
May 14, 2010. 5:32 PMBuzzsushi says:
Also if u kill ur buddeh in front of the mystery box, then open the mystery box until right before it choses the weapon, start reviving your buddeh, then right before he gets revived pick up the weapon and you get 3 weapons.
May 15, 2010. 3:23 AMKNEXFRANTIC says:
awsome hey do you have a ps3
May 15, 2010. 8:22 AMBuzzsushi says:
Nope. Xbox ftw.
May 16, 2010. 8:40 AMKNEXFRANTIC says:
hey your my 200th comenter yeah 200 yeah woo yah
May 13, 2010. 12:17 PMKNEXFRANTIC says:
why i never do
Mar 23, 2010. 9:41 PMPhantom few3 says:
Dont get me wrong, the ray gun is awesome at long distance but after a while it starts to suck. Espicially when the rounds explode and they dont work at long range
Feb 24, 2010. 1:39 PMKNEXFRANTIC says:
what console do you have it on . and omg you have an almost identicly tactic to me
Feb 8, 2010. 11:12 PMBartboy says:
I thought of something cool.
If you have a ray gun and no ammo (and you're doing a glitch with 4 people, on verruckt) you can die, then when you're in the last stand phase you get some ammo, so you shoot it, get revived, then kill yourself again etc....
1-40 of 76next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:Liberty Prime
Sup.
