3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Need Free Water? Build a Rain Barrel
For the price of a 55 gallon plastic barrel (sometimes free), and about $10 in parts, you can build your own rainwater collection system. Water is good. Free water is better.
If you already know that water won't run uphill and how to handle a drill, you can do this. The most ingenious part of the design is the hose-to-barrel connection. Since the attached hose will frequently be tugged during normal use, it is important to use a mechanical connection rather than a glued connection.
This design uses a simple garden hose washer, standard garden hose parts, and a special adapter, that's not really all that special. It's expandable and useful for more than just capturing rain water.
Step 1Got Parts?
Got Parts?
You will need a barrel. The bigger the better. 55 gallon is good. I like plastic, but metal will work. Don't use barrels that held something toxic in a former life, go for something wholesome, like lawn fertilizer, or laundry detergent. I picked up this one at a local recycler for $4.
Also, while in town, pick up a garden hose valve, garden hose washer, and a MHT to FPT 3/4" plastic adapter. What? MHT = Male Hose Thread. FPT = Female Pipe Thread. Plastic = plastic. You'll know it when you see it. Less than $10 total.
I had some old parts handy to draw from.
The gutter modification comes later.
92 comments
1-40 of 92next »
Dec 17, 2010. 10:03 PMzilcho says:
if your going to drink it i would add some water filters
Mar 19, 2011. 7:48 PMgroovy says:
Bad choice of avatar........
Apr 10, 2012. 1:29 PMkkarwan says:
and your name is great?
Mar 20, 2011. 3:42 PMzilcho says:
How so?
Jun 23, 2011. 9:05 AMbwells2 says:
Do you know how much money it will save on your water bill? That is amazing! Thank you for sharing.
Aug 29, 2009. 12:41 PMkkarwan says:
you should realy filter the water and boil it before ingesting as it can pick up tar bird manure, and solvents off f a roof not to mention the noxious chemicals that are in our atmosphere, that this water was recently in contact with.
Jul 28, 2011. 1:24 AMjfellens says:
We simply placed some feeder goldfish in our rain barrell to eat the mosquito larvae.
May 7, 2010. 9:36 PMkhalednm says:
 has anyone looked into putting a deionizer into the spigot setup?  This would eliminate the risk of acid rain... and an activated charcoal filter should remove any other contaminants...
Jul 15, 2011. 7:29 AMled_scorched says:
The rain just ran over a roof.... I'd be more worried about what it picked up there (tar, solvents, bird poo, etc) than I would be about acid rain. This is meant for grey water type uses - drinking water is cheap enough (fractions of a cents a gallon) that I wouldn't recommend trying to pinch those pennies.
Jul 14, 2011. 12:52 PMtastethefruit says:
Very nice rain barrel - simple and easy. I have built something similar, but tie the barrels together. I use a small pump from Home Depot to empty the barrels.
You can see the beast here...
http://greenterrafirma.com/DIY_Rain_Barrel.html
Also includes step by step instructions with pictures.
Jun 13, 2011. 10:38 PMintel_intel says:
thenk
Mar 30, 2011. 7:50 AMgreenlivingeco says:
We just built our own rain barrel too. It is a little different from the one built in the post. Check out our step by step make a rain barrel guide to see how we built ours.
Mar 12, 2011. 2:45 PMgarden goddess says:
Nice job! We have a similar design, and it works great!
Mar 12, 2011. 2:46 PMgarden goddess says:
Oops! Meant to include our design for comparison: http://tylertork.com/diyrainbarrels/construction.html
Jan 18, 2011. 10:57 AMezgnann says:
I am having some trouble finding food grade barrels in my area (northern Louisiana). Is there any reason why 55 gallon plastic trashcans cannot be used? they are readily available, reasonable, and durable?
Jul 31, 2010. 10:00 PMcytoxin says:
Where did you get the parts for the hose connectors? I checked Home Depot and Lowes and couldn't find anything like these...
Jun 27, 2010. 10:48 AMjpatramirez says:
what would someone recommend if you do not have a downspout? our pitched roof homes in El Paso TX do not normally have these attached...is there another way to collect water without downspout?
Jul 9, 2010. 6:53 AMaptd27 says:
@jpatramirez You would need a downspout diverter... you can get them here:
Rain Barrels
Apr 26, 2010. 3:17 PMeddy14777 says:
great thought but if you live somewhere with power plants basically in your back yard this could produce acid rain
May 26, 2010. 3:58 PMbecca-boo says:
 Acid rain is fairly common, true, but the water that is being collected should only be used to water gardens, wash cars, etc.; every thing that would be exposed to the rain already. This water shouldn't be used as drinking water for sure, it's not exactly the definition of potable water.
May 9, 2010. 8:25 AMRyutso says:
Or you flip the rain barrel over and have someone stand inside it and hold the 2 parts.
Apr 9, 2010. 5:35 AMmclelm says:
Rainwater Harvesting systems are great; I have two barrels in two locations.  I don't know if anyone mentioned this (I didn't read the 69 comments), but if you've got this type of white barrel or any other translucent barrel anywhere the sun shines on them, algae will grow; at least it did on my white barrel.  The barrel will have to be shielded in some way- by painting the barrel or some sort of solid box, trellis with vines, etc.
Feb 18, 2010. 11:23 AMSkylerk says:
There is an awesome rain barrel diverter called RainReserve. And it has a large spigot that can do up to 10GPM. And to modernmans question: the diverter and attachments are closed, so that water will go back up the tubing into the diverter and out the downspout. Found at:
http://www.rainreserve.com
Aug 16, 2007. 3:08 PM!Andrew_Modder! says:
ya, just collect it, strain it then purify or boil it! P.S. there is a company in texas selling bottled rain water, and they claim the mineral content makes the water taste almost a little sweet, and is defiantly difrent from your avrage water. I think im gona do this instructable, because where i live in Cuyahoga Falls, Ohio our water is bad (its really hard) and super calciumic (i made that word up so dont comment me on that word!)
Jan 16, 2010. 7:38 PMlancesb says:
I partly agree with with Dessyl, I've researched many of  the polluted rivers around the Great Lakes/ MidWest/ Northern Appalachia, & I wouldn't trust any tap water there either. But have you considered where you rain water comes from? You might want to do some research into acid rain, which was most prevelant around those same rivers & lakes. Texas (except for oil production metros like Houston), the SW, & the Rocky Mt states have purer rain water because it's evaporated from cleaner sources. I would say to anybody, if you don't like your tap water, do not drink you rainwater. & if you're using it for gardening maybe at least test the pH before you use it on expensive plants. Good luck.
Aug 17, 2007. 10:30 AMerniesthings says:
Down in wadsworth area, I was given a free barrel in may. I haven't had to turn on the garden hose once this summer. I was close back in july. I was just given 2 more barrels. I have one hooked up. Probably won't hook the other one up until spring. I might actually water the lawn next summer.
Aug 17, 2007. 8:16 AMDessyl says:
Yeah, I live in Stow, Ohio (which is right next to Cuyahoga Falls for those who don't know) and the water is pretty bad. But it isn't as bad as it used to be. At one point the the Cuyahoga River caught on fire near Cleveland due to the pollution (A long time ago). However, now the water just smells and tastes bad. This is a good idea. You can use the water for pretty much anything, but I have a few concerns. Because it is relatively stagnant water bacteria and algae can build up and mosquitoes may be attracted to it.
Jun 13, 2008. 8:50 AMGoedjn says:
That's why people keep goldfish in their rain barrels. they eat the mosquito larvae.
Aug 17, 2007. 4:13 AMKiteman says:
(There's a brand of processed cheese sold in the UK with the tag "It's calci-yummy")
Sep 26, 2007. 2:26 AMamethysteria says:
We have a dairy-based dessert called "Calci-yum"
Aug 16, 2007. 4:37 PMspike shadows (secret agent man) says:
its like that all over northeast ohio. barbertons' is terrible at the irst of the month
Oct 9, 2008. 6:46 AMbfarm says:
What happens in Winter / freezing conditions? Can picture a frozen barrel with a massive run off of melting rooftop snow all pouring out next to the house's foundation. Maybe a much larger overflow? I'm thinking of using this set up connected to soaker hoses to water the landscaping.
Sep 20, 2009. 7:45 PMplumber4 says:
The water works fine in the soaker hose. Not all of the water needs to be drained in the winter. When the water freezes, it must have enough room for expansion. If it doesn't the barrel may crack. Being that the walls of most barrels are so thick, I doubt that they would split. If you have metal fittings or piping, the water needs to be drained.
Aug 12, 2009. 2:08 AMjames.mcglashan says:
what do u mean clean water there are no filters and the water has things from the gutter?????????
Jun 28, 2009. 2:11 PMrowerwet says:
to keep most of the junk out of my rain barrel, I cut my downspout about 7' above the ground, and put a PVC 3"X3"X2" hub on the end of downspout. the 2" is on the side at a 45 degree angle going down, coming off the lower 3" is a pipe that goes almost to the ground with a ball valve on the end. the two inch pipe slopes off to another 45 degree bend that dumps into the rain barrel bung (no cutting involved). I leave the ball valve shut and empty it out after each rain storm, this pipe captures the dirt and leaves that get washed out of the gutter, and after the pipe fills the rest of the water goes into the barrel. During the winter I leave the ball valve open and it drops directly into a grate that drains into under ground perforated pipe to carry the water away from my foundation, the over flow from the barrel goes to the same drain pipe. after all the water above the ball valve is emptied into the watering can, I siphon into the watering can from the other barrel bung with a "shaker" siphon (has a valve on the end with a marble in it to start the flow by rocking the hose in and out.
Jul 24, 2008. 4:23 PMJouda Mann says:
I wonder if this can be optimized for keeping mosquitoes out. I live in nort Texas, and there is local legislation being discussed which will outlaw standing water because of the dangers of West Nile and so on. Could your design be modified to something like this?
Jun 29, 2009. 9:31 AMjesmedley says:
I just toss a mosquito "dunk" into the barrel.
1-40 of 92next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:McSensei
