Nendoroid Vampire Coffin
407
Posted
Introduction: Nendoroid Vampire Coffin
This is a cute little Halloween prop for your Nendoroid.
You will need:
  • 3D printer or printing service like Shapeways, black filament
  • Red felt
  • Hot glue
  • Paper
  • Pencil
  • Scissors
  • Pins
Step 1: 3D Print Coffin
3D print the coffin in black. I used an Ultimaker 2+ with a fast print (Cura) in black PLA. If you do not have access to a 3D printer via your library, school, maker space, etc, you can use a 3D printing service like Shapeways.
I modified the dimensions of this design. I did not print the lid. I have attached the OpenSCAD file in case you want to modify the dimensions.
Step 2: Create Lining Pattern
Trace the outside of the coffin on paper. Carefully trim the bottom edge and the bottom left/right edges to fit the inner dimensions of the coffin. Push the pattern down into the base of the coffin and align the bottom and bottom left/right edges. Use your fingernail to fold the top and top left/right edges at a right angle to get the right dimensions.
To create the pattern for the other inside surfaces, I measured the inside dimensions of the coffin and created patterns in Inkscape. That file is attached for you to print and cut out.
Step 3: Cut Out Lining
Pin the patterns to the red felt and cut them out. Be sure to keep track of which piece goes with which edge.
Step 4: Glue Lining
First, glue the base down. Then start applying the felt panels to the inside edge. You will need to trim them down slightly - otherwise they will overlap. Apply one panel at a time and trim accordingly. For the long panels, only apply glue to part of the coffin, get it lined up, then glue down the rest.
Step 5: Have Fun!
Your coffin is now complete! Go forth and do Halloween photoshoots. :)
  • Minecraft Challenge 2018
  • Gluten Free Challenge
  • Sew Warm Contest 2018
2 Comments
Awesome. One of the main reasons why I want a 3D printer is so that I could make custom accessories for my kid's toys.
Thanks! I'd like to get into 3D printing more doll-sized furniture as well.
